Old 04-30-2009, 02:20 PM
HankMcSpank is on a distinguished road
My table moves the wrong way when using jog arrows?!!!
When I press the tab button to get the jog windown up & then use the shuttle arrows - if I press the top green Y+ ...I'd have expected the table to move away from me, when I press the right pointing X+, I'd have expected the table to move to the right - are these correct assumptions? (becuase at the minute my table does the exact opposite to the above - if it shouldn't act in this manner...how do i resolve this please?!!!)
Old 04-30-2009, 02:25 PM
Shoprag is on a distinguished road
table vs. tool movement
keep in mind that the + and - buttons are used to position the tool on the part. If you want the tool to move in a + direction the table will move in a minus direction. This assumes you are using a vertical machine.
If, for some reason, the tables are now moving in the opposite direction that they used to check that mirror image has not been set on by accident.
Old 05-06-2009, 08:25 AM
Thank you for your response...that was indeed my issue.
that said, i have a real whacky transport problem now.
My Y table is now fine ...in other words, I press either a Y+ or Y- & the table moves just fine in either direction.
However my X axis...no matter whether I press the X+ or X- ...my motor turns the same way. (the table only goes one way).
I thought perhaps a wiring fault. Therefore, I moved the Y axis motor (which is the same motor type/wiring & working fine) & connected it to my driver board's X motor output - same thing (X only only moves in one direction, no matter whether X+ or X- is pressed!)
Since I've ruled out the motor & wiring, this can only mean it's either the board (X axis screwed?), or some setting in Mach3??
....HELP!!!
Old 05-06-2009, 10:21 AM
ger21's Avatar
Check the voltage on the direction pin, while jogging in both directions. Should be 5V one way, and 0V the other.
Need Help!- y home moves over japco43 Machine Problems, Solutions , Wireless DNC, serial port 0 03-11-2009 06:34 AM
Someone correct me if I am wrong about my new router table CncForMe DIY-CNC Router Table Machines 0 12-22-2008 07:25 PM
Need Help!- Getting some bad moves. Stampede BobCad-Cam 1 09-26-2008 07:47 PM
Can't use keypad arrows bcnc Mach Mill 1 10-24-2007 07:28 PM
wrong approach with xy-table? sweFredrik DIY-CNC Router Table Machines 2 06-28-2007 08:59 AM
