| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
Hello All I Very Like Make a Little Cnc Machine but i have problem is to Please See The Picture Below Hardware ----------------- I buy 3 Axis Stepping Motor (Start Shaphon 23HS3002) ![]() My Motor ![]() Buy 3 Step Driver (MS-2H057M) And Set It ![]() My Drive ![]() Buy Pmdx-122 and Set It ![]() Assembly In Box Below ![]() ![]() Buy Dc 9V Adaptor ![]() Conect Stepping Motor to conector ![]() ![]() Connect All To Box and Pc By Db 25 ![]() Software --------------- Install Win Xp sp2 And Optimisation it Install Mach3 VR2.42 Conect pc to Board (Pmdx-122 ) Pic S09.jpg restart System (when System restart Relay in Board is On&Off ) Run Driver Test And Pic S1 in Below ![]() Run Mach3Mill 1- Config - select native Unit and select MM's 2- Config -Port And Pin - Pic Below ![]() ![]() ![]() 3- I don't know, how set Motor tuning and other config . I have a problem - Motor in not work Properly. Film in Below Do You Help Me . tank's a lot Mach3 , Config, Motor Tuning problem ( FILM OF MOTOR) Last edited by MDF_Markazi; 04-29-2009 at 03:53 AM. |
| I think your stepdrive is set way to high, as far as i can tell its set at 8000 steps per rev, try setting it to the lowest value = 400 step per rev. In mach 3 set step per unit to the same, 400 and increase acceleration to maybe 100. Now in the MDI enter G0 Y1 and the motor should spin one full turn. Also make sure you have set the Unit in the config menu to mm not inches |
But I Think On Dip On (down) = 0 Off = 1 do you think unlike |
| Hello EveryBody I detect Problem & crash Sound the wire Of A A_ b b_ is malapropos Then In config - motor tuning and setup change Step Per : 400 Velocity :100 Acc : 30 Step Pulse : 0 What is this? dir Pulse : 0 What is this? Then Motor rotate Corectly -but Only rotate Left To right if is X Axis more not Rotate Right to Left when X is less Where problem ? ![]() in the course of Dip On Step Driver On=0 Off=1 |
| motor tuning problem | m8kingit | Mach Mill | 3 | 04-28-2009 09:39 PM |
| Mach3 and G-Rex motor tuning Math help Please | eat | G-REX | 1 | 10-17-2007 11:16 AM |
| Motor tuning under Mach3 | BAustin | Industrial Hobbies (Support forum) | 3 | 12-23-2006 11:23 PM |
| Mach3 motor tuning question | kn6398 | Machines running Mach Software | 9 | 04-04-2006 10:07 PM |
| Mach2 motor tuning problem??? | kombayotch | Mach Mill | 10 | 03-15-2006 02:34 PM |
