| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
I have 1.8 degree steppers being run by 10 microstepping drives. I have 24 tooth, 20 pitch, 1.2" diametrical pitch spur gear attached to the motor This runs on a 20 pitch 14.5 degree pressure angle rack Can someone calculate my steps per inch as I simply cant figure out the formula :x Thanks so much! |
| Hi, If the diametral pitch of the spur gear is 1.2" then the "traveled" circumference is 1.2*Pi or 3.7699". So, 2000 steps = 3.7699" and 2000/3.7699 = 530.218 steps/inch. EDIT: OR....when I think about it, diametral pitch might actually mean "traveled" distance per revolution of the gear and if that is the case then it's 2000 / 1.2 = 1666.667 steps/inch instead. Sorry for the confusion. /Henrik. |
| Calculating Steps with Xylotex Board | cxixer | Machines running Mach Software | 5 | 05-19-2008 08:10 AM |
| Need help on calculating steps | rustamd | Mach Software (ArtSoft software) | 17 | 08-03-2007 07:08 AM |
| Calculating steps per revolution | watsonstudios | Mach Software (ArtSoft software) | 1 | 06-25-2007 01:22 PM |
| Calculating "steps per unit" for rotary axis? | Beezer | Mach Software (ArtSoft software) | 2 | 11-28-2004 03:31 PM |
| calculatiing pinion size for rack and pinion setup | Apples | DIY-CNC Router Table Machines | 3 | 05-18-2004 09:36 PM |
