Old 04-26-2009, 02:19 AM
happytriger2000's Avatar
happytriger2000 is on a distinguished road
CNC4PC MPG pendent + C22 setup
Hi everyone,
Here is another thread from me, hope you can help. I'm new to MAch3 so go easy on me.
I bought a MPG pendent + C22 adaptor for LPT2 from CNC4PC, had the adaptor connected to LPT2, followed this link for setups:
http://www.cnc4pc.com/Tech_Docs/guid..._over_LPT2.htm
LPT 2 and LPt 3 = Sunix 4018a 2 ports Parallel Universal PCI Board ( http://www.sunix.com.tw/it/en/Produc...a_id=0&sid=479)
In Mach 3 ----->Config ------> Ports and Pin :
enabled Port #1 = 0378 (port address)
enabled Port #2 = the LPT 2 port address,
To check the LPT 2 port address ----> Device manager ------> Ports (com & LPT) ----> PCI EPP/ECP Parallel Port (LPT2)-----> Resources ------> SNXPCARD_ENUM\SNXPCARD_PARPECP\1409&7268_01041409_00F0_PORT1
What should I put in the LPT 2port address in Mach 3? is it 00F0? or...
Freddy
Old 05-02-2009, 09:46 AM
Problem solved!!, Change the Pararell PCI card to another brand that uses Moschip.
DSP pendent -how it works? Fonfon Open Source Controller Boards 1 02-28-2009 01:06 PM
CNC4PC C6 Speed Controller setup? vlmarshall LinuxCNC (formerly EMC2) 6 02-23-2009 05:39 AM
Problem- cnc4pc pendent davidponte Mach Mill 1 12-26-2008 12:28 AM
Xylotex and CNC4PC setup with mach3 bruno123 Xylotex 3 05-03-2007 12:08 AM
