Old 04-20-2009, 10:10 PM
HBFixedGear is on a distinguished road
Mach closed loop?
Anyone out there ever run Mach 3 closed loop? I understand Galil has a 4 axis motion board that will interface for closed loop instalations.
Old 04-20-2009, 10:51 PM
TOTALLYRC is on a distinguished road
Mach3 closed loop.
See my build log for the dspmc/ip controller.
http://www.cnczone.com/forums/showthread.php?t=66994
Mike
Old 04-21-2009, 12:50 AM
mach 3 closed loop
Mike,
Thanks for the info. Complicated project, I can relate. We are thinking of using mach 3 to develop a 6+ axis machine. Essentially a small lathe with c & y axis plus 1 odd extra. it will be a dedicated machine for in house use. I have 3 Hardinge HC chuckers that we no longer use in our process so they are the likely candidates for the sacrifice.
Regards
Old 04-21-2009, 01:40 AM
I am currenlty doing a lathe retrofit on a Tsugami spl lathe.
I really like the controller and how it works.
I am glad the info was helpful.
If you order one, say hi to Rufi for me.
Mike
Tags
closed loop, encoder, feedback, mach 3, servo
Open Loop to Closed Loop Stepper Conversion beamhome Stepper Motors and Drives 9 05-24-2012 02:46 AM
question on closed loop vs open loop (servo systems) boonie Servo Motors and Drives 20 11-09-2007 12:30 PM
Mach 3 closed loop ? efrem Mach Mill 5 12-06-2006 07:01 PM
Lathe conversion - open loop vs closed loop bhowden General Metal Working Machines 7 03-21-2006 03:56 PM
Closed Loop Driver vs. Closed Loop Computer ojibberish Gecko Drives 3 06-08-2004 11:30 AM
