| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
I was thinking about buying a Shuttlepro to use as a pendant with Mach. I am looking for comments from anyone who has used one. Do they serve the purpose OK, or are they clumsy to use? I really don't want to spend close to $200 on a real one just yet. I see used Shuttlepros on ebay for under $40. Thanks, John |
| A question to all that are using a shuttle. Have you used an MPG. My guess is no, that was the case with myself till a week ago. I now have an MPG, there is no comparison between them. Cons with the shuttle, in my case changing direction i still had a couple of steps in the wrong direction before the change in direction. Sometimes when jogging i would release the fast jog button but it would continue to jog sometimes forcing an estop. That fact is documented on the Mach users forum. Now the MPG i can spin two turns forward then half a turn back look at the dial the machine will come to rest at the exact position indicated on the MPG. When setup i can see the jog rate as indicated on the selector switch. Currently set one turn is either 100mm, 10mm, or 1mm Phil |
| Phil, No doubt an encoder controled MPG is going to be far superior, however the Shuttle Pro is a easy all in one solution for some users that dont want to build up a pendent. I prefer the encoder driven MPG by the way. Jeff...
__________________ Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish. |
#10
I hear ya on the pukka MPG....Only probs is that I'd have to get the dogs danglies from P Homman
__________________ Keith |
#11
| Kipper the shuttle also leaves a lot to be desired on shape. It is meant to be used flat on a table not picked up all the time. I had a DTI in the chuck went to pick up the shuttle it slipped from my grip and hit the spindle key on the keyboard. ![]() I am not saying a shuttle is bad just not as good as an MPG from here http://www.cnc4pc.com/Store/osc/index.php Phil |
#12
Or make one so much to do and so little time!
| Mach3 and ShuttlePro 2 Help | tullsnr | Mach Wizards, Macros, & Addons | 1 | 11-01-2007 05:26 AM |
| NUM PAD Pendant? | bigz1 | DIY-CNC Router Table Machines | 2 | 05-15-2007 09:32 PM |
| MPG pendant | troy676zsj | Fadal | 0 | 07-30-2006 09:15 PM |
| Anyone using this pendant? | trevorhinze | Mach Mill | 3 | 09-10-2005 07:45 AM |
| Pendant? | CNCadmin | Carken Products (Deskam, DeskCNC etc) | 0 | 05-07-2004 09:10 AM |
