| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
Has anyone used mach to run a robot. What I'm trying to do is retro fit a Yamaha 3 axis robot, which shouldn't be that hard, but I also want the robot to cycle automatically using a sensor to start the cycle. |
| you can, There is a Plug in called "JogLearn" from the plugins download page, all you would do is use a MPG to position the arm and do its thing, and the plugin records the motion. you then save it, and the motion and routine saves as a Gcode file, that you can Run and the robot will repeat the motion everytime you run the G code. scott
__________________ Commercial Mach3: Screens, Wizards, Plugins, Brains,PLCs, Macros, ATC's, machine design/build, retrofit, EMC2, Prototyping. http://sites.google.com/site/volunteerfablab/ |
| oh, ok Then do this, bring in your sensor to, lets say INPUT4 in mach3, in Brains, map INPUT4, through a No-op lobe then terminate it with the "Cycle Start" button. For safty if you want you could also interlock the cycle start with a LED that when that LED is ON, then it would disable the cycle start. You could also do it in the Macropump using VB, or a Plugin. scott
| Need A Quote- Looking for Robot Auto Palletising (Panarobo and or STORK Robot) | rsarwanto | Europe Club House | 0 | 09-12-2008 06:22 AM |
| Mach 3 robot? | pointcloud | Mach Mill | 2 | 03-25-2007 09:08 AM |
| Confused: Mach Turn, Mach Mill, Mach 2/3 ? | CanSir | Mach Software (ArtSoft software) | 5 | 02-16-2007 04:41 AM |
| CNC to Robot | GT_racing | G-Code Programing | 0 | 05-24-2006 08:18 AM |
| robot arm help | magicruss | RC Robotics & Autonomous Robots | 5 | 03-01-2005 11:06 PM |
