| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
What the plug in does is watch directly the Signals Of ALL the "Ports and Pins" Input Signals and Output Signals so you dont have to use a: "Brain", or "Macropump" or other VB device to map these signals to a Screen LED that represents that Signal. The Screenset called: "1024 TestIO.set" is the standard OEM Mach Mill Screen with ALL the standard Input/Output signals on the redone Diagnostics page. Below is a list of the User LEDs that the Plug in uses If you want to use this plug in and screen set then you will need to check to make sure that your Wizards, screens, or other items are not ALSO using these. The Plug in will "tie in" LEDs for the Standard Input and Output Signals under Ports and pins for: Inputs: 1). OEMTrigger's 1-15 Outputs: 1). OUTPUT's 7-20 2). Charge Pump, Charge Pump2, and Current Hi/Low ULED's Used for Input Signals are: 1). 1301-15 is used for OEM trigs 1-15 ULED's Used for Output Signals are: 1). 1316-32 is used for Outputs 7-15,Charge Pump, Charge Pump2 and Current Hi/Low Link to download on Machsupport: http://www.machsupport.com/forum/ind...c,10861.0.html Screen Shots and installer attached to the above link. scott
__________________ Commercial Mach3: Screens, Wizards, Plugins, Brains,PLCs, Macros, ATC's, machine design/build, retrofit, EMC2, Prototyping. http://sites.google.com/site/volunteerfablab/ |
| Need Help!- fanuc 0t pmc diagnostic parameters | machineryaxis | Fanuc | 5 | 03-22-2009 01:49 AM |
| Error codes from diagnostic screen | nelZ | CamSoft Products | 6 | 10-09-2008 03:17 AM |
| Problem- Diagnostic on 0TB | guhl | Fanuc | 4 | 09-23-2008 02:28 AM |
| Diagnostic ? | grahamshere | DIY-CNC Router Table Machines | 12 | 08-11-2008 11:08 AM |
| New plasma screen. ( Input needed) | ynneb | Screen Layouts, Post Processors & Misc | 23 | 10-13-2006 08:48 AM |
