Old 03-03-2009, 06:23 PM
functionbikes is on a distinguished road
How do I set the z axis plane
I need a little input here, could someone tell me where in the mach software do you assign the jog for .001,.010,etc am i missing something
Old 03-03-2009, 06:36 PM
ger21's Avatar
Config>General Config, or try the tab key.
Mill/turn Multi axis work plane question bassn_07 Esprit 9 06-01-2008 03:07 AM
Problem- Z axis not clearing feed plane Jblk9695 Haas Mills 7 05-01-2008 10:15 PM
How would I code a surface cut radiused in the y-Z plane around an x axis centerline? RogerRetro G-Code Programing 19 09-18-2007 07:48 PM
construction plane and tool plane nervis1 Mastercam 9 11-04-2004 11:53 PM
cycles initial plane/retract plane HuFlungDung OneCNC 25 06-26-2003 07:02 PM
