Old 02-26-2009, 09:43 PM
Delanoman is on a distinguished road
Cutting a basic part in order
I made my drawing on Delta cad, saved as a DFX file. Loaded it into Lazycam and turned it into a Gcode file, then transferred it into Mach3. The Gcode is given a bunch of Z values which are unnecessary (i deleted then in microsoft notpad) but how do i keep these from reappearing?
Also say i made a square shaped object. I want it to be cut out in a rotational pastern, not just random lines at a time, how do I fix this as well? THANKS
TMCAD or TM Cutting software cut order issue hydravien Torchmate 3 03-02-2009 02:48 AM
Need Help!- Cutting Order John999 Torchmate 2 11-05-2008 02:40 PM
cutting order older lazy cam alex 850 Mach Software (ArtSoft software) 1 08-18-2008 05:58 PM
Machining my part with out cutting everything desktoprouters Solidworks 10 02-14-2007 02:06 PM
Cutting a part out MagTDK MadCAM 8 10-13-2006 11:31 AM
