Old 02-16-2009, 11:02 AM
PoppaBear10's Avatar
PoppaBear10 is on a distinguished road
Need a THC beta tester please....
Greetings,
I am doing a Plugin for a THC (Torch Height Control) OEM and Mach3.
I am in the East TN area close to Knoxville, and would like someone local who is building a Plazma table, and plans on using a Step/Dir Z drive for control. The Plazma unit that you are using or Planning to use MUST give off a 1-10V analog out put that represents the top and bottom voltage range at the Plazma working end.
The OEM is willing to donate to you the THC Hardware as part of the compensation for your help and trouble. BUT, you must supply a working 3 axis table, and Plazma cuttin unit that does the above.
Scott
Commercial Mach3: Screens, Wizards, Plugins, Brains,PLCs, Macros, ATC's, machine design/build, retrofit, EMC2, Prototyping. http://sites.google.com/site/volunteerfablab/
webster hardness tester hkrok Product Announcements & Manufacturer News 0 11-19-2008 05:59 PM
Dc servo tester happytriger2000 Servo Motors and Drives 0 08-12-2008 06:04 PM
GREX100 Tester problems Mr.Nerd G-REX 7 11-24-2007 03:05 PM
printer port tester smarbaga General Electronics Discussion 1 12-10-2005 11:57 AM
Building a Load Tester lerman Servo Motors and Drives 1 11-06-2005 09:10 AM
