Old 12-13-2004, 12:05 AM
*Registered User*
fpworks is on a distinguished road
Direction Prechange setting
What exactly does this mean?
Thanks,
Justin
Old 12-13-2004, 12:21 AM
TommyB is on a distinguished road
This is basically a delay that the software uses to delay steps to the drive after switching direction. Some drives need a certain amount of time delay after direction changes to move properly. I just ran into this problem tonight. I have a driver that i built based on the allegro sla7026 chip driven by the 5804 that needs a 3uS delay. Before I adjusted it, the z was missing steps, now it runs perfectly.
Old 12-13-2004, 06:59 AM
ger21's Avatar
Mach3 has some changes to this to allow larger settings, if you need them. I think Mach2 is limited to 28uS. I think you can set it higher, but thats all you'll get. But you most likely won't need it nearly that high.
Old 12-14-2004, 11:05 PM
*Registered User*
Thanks,
The Mach2 manual didn't say much about "direction prechange." I goofed with that setting a little...my steppers made some weird noises around 20uS so I figured I would stop trying to fix something that isn't broken.
Thanks again,
Justin
Help setting up turbocnc 4.01..?? lurch TurboCNC 4 05-07-2005 04:57 AM
Need help setting up new machine Hack TurboCNC 6 05-03-2005 12:22 AM
motor direction sixpence Mach Software (ArtSoft software) 2 12-28-2004 11:15 PM
running direction problems gv71 Yeager Automation 1 10-27-2004 08:19 AM
z axis direction question. ljoe1969 TurboCNC 3 05-21-2004 09:53 PM
