Old 12-09-2004, 03:22 PM
qsacracer is on a distinguished road
Mach 2 & Win 2000
I have windows 2000 in a 1200 mhz dell computer that I want to use Mach2 with..I don't have the Windows 2000 disc to do a clean install so my question is does everything need to be turned off when I CTL,ALT,DLT...or should something need to keep running............also on a Taig Mill how do you home out with no limit switches...do you use safe Z.....Thanks...
Old 12-09-2004, 08:53 PM
ger21's Avatar
Are you talking about processes? You can't remove them all.
Download msconfig from here:
http://www.perfectdrivers.com/howto/msconfig.html
You can remove just about everything in the startup section. When you reboot, you should be much better off.
Old 12-10-2004, 12:22 PM
Thanks that is exactly what I needed....I did not know that win 2000 did not come with msconfig till I tried it and.....................Nothing
The computer with Win 2000 is dedicated to my Mach2 software so I guess I only need system tray running..is this correct?
I am waiting on my mill to arrive but I want to pin things down before hand..
Old 12-10-2004, 12:27 PM
ger21's Avatar
I thought I read on the Mach2 forum to delete eveything in the startup tab, but don't take my word for it.
Old 12-10-2004, 01:37 PM
Ok now I am really pleased......Thanks Gerry..........I ran msconfig and turned everything off..hooked up my Driver box and steppers....configured Mach2 and ran some programs...everything works fine though I had some skipping at 60 ipm and backed it down to 50 ipm and works great.....now I am Really hooked Thank you for the advice.....1 more question since I only ran the motors Dry (off the Machine) will I have to fine tune a little more under a load when I install them........I am thinking yes
Old 12-10-2004, 02:00 PM
ger21's Avatar
Most Definately.
Need Mach 2 configuration help for Sherline 5410 wilit Mach Mill 14 01-15-2010 08:06 AM
Mach / geckos or DTLLC drivers zcases Mach Software (ArtSoft software) 3 01-11-2007 08:06 PM
Mach 2 and settings tauscnc Commercial CNC Wood Routers 4 05-25-2005 10:05 AM
Mach 2 slow on Intel Centrino P1.6 Notebook daddyhobby Mach Software (ArtSoft software) 7 03-28-2005 08:33 AM
Proper Computer and Chip for Mach 1 HomeCNC Mach Software (ArtSoft software) 12 03-17-2004 10:14 PM
