| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
My friend was using mach 1 and it worked perfect, so than he upgraded to mach 2 and could not get one axis to work in both direction. the z and the y would move perfectly but the x would only move in one direction. What on earth could cause this? Mind you that all the hardware is working and it seam to me a mach 2 issue.
__________________ Thank You, Paul G Site Owner-Webmaster- Administrator www.rfqwork.com www.cnczone.com www.welderzone.com |
| Mach2 can be fussy with computer hardware. Did he try the special driver? There is a file called specialdriver.bat in the program folder. If this doesn't solve it, try a different version of Mach2. Version 6.11 is the current stable release, but there is a version 4.xx available too. Let us know how you get on. Just a thought - there are settings for direction pre-change and for pulse width in the motor tuning sections, might be worth a look?
| When you uninstalled Mach1 did you also uninstall the hardware driver then reboot before installing Mach 2?
__________________ Thanks Jeff Davis (HomeCNC) http://www.homecnc.info (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Do it again! I have had trouble many times from a funny install. And re-check your pin callouts, and HOT keys.
Hope that is a little help |
| Okuma LC-20 Threading problem | Gunner | Machine Problems, Solutions , Wireless DNC, serial port | 13 | 12-13-2011 11:11 PM |
| Beginner Troubleshooting and Building Considerations | coherent | FAQ of CNC Machine building | 3 | 11-10-2011 02:27 PM |
| Mach 2 Estop problem | dentman | Mach Software (ArtSoft software) | 9 | 06-07-2005 08:32 PM |
| Mach 2 and settings | tauscnc | Commercial CNC Wood Routers | 4 | 05-25-2005 10:05 AM |
| Proper Computer and Chip for Mach 1 | HomeCNC | Mach Software (ArtSoft software) | 12 | 03-17-2004 10:14 PM |
