| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
I have been trying to run the driver test program in Mach 3. When I go into the program files and click on the driver test file nothing happens. Do I need to look for the file in another place? I am using Windows Vista OS. |
| Vista requires a two stage installation! Step 1: Delete the Mach3 installation completely. Step 2: Make sure the directory C:\Mach3 is removed. Step 3: Install Mach3 , it will prompt you to install the driver, make sure you check the install driver option during the installation. Step 4: The installation will prompt you to reboot, make sure you reboot. Second stage: Step 5: download the file "memoryoverride" it is attached to this post. Step 6: Run the "memoryoverride" program, just double click it. It modifies the registry to allow MAch3 driver to run. Step 7: Go to the C:\Mach3 folder, (or wherever you installed Mach3) and right click drivertest.exe , select "Run as Adminstrator.". It should tell you to reboot. Do so, or you will crash. No question about it.. Step 8: Run the drivertest.exe again, and it should run. Note: You may get errors reported when running DriverTest, in fact it may not run at all first time, then Vista will ask you if you wish to run it in compatability mode. DO so, and it will run.. Jeff... |
| Problem- Driver test question | woodr004 | Machines running Mach Software | 5 | 01-12-2009 10:12 AM |
| Test Running the new G230 Vampire drivers on a mill drill | Dan Mauch | Gecko Drives | 2 | 11-12-2006 08:58 PM |
| Test steppers with driver only? | monte55 | Xylotex | 0 | 10-19-2006 06:55 PM |
| Mach2 - test ocx program shows running at only 96 pulses/sec | nikolatesla20 | Mach Mill | 6 | 05-29-2006 10:12 AM |
| Running with a wave driver , too fast? | Konstantin | TurboCNC | 1 | 03-30-2004 04:11 PM |
