| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
What formulas do you use to calculate "steps per unit" for the motor settings in regards to the A - axis (rotary)? I have gone through the Mach2 manual and I can't quite figure out if you use the same formula used to calculate linear axises or some variant of it. For some reason I am just drawing a blank. I am going to be using a stepper motor directly mounted to a gearhead which has a 50/1 ratio and I will be using a Xylotex driver in 1/8th micro-stepping mode. Anyone know what the proper formulas I need to use? Thanks |
| I would assume you want to program pulses/degree? If it is a rotary axis. First, how many motor pulses for one rev of the motor?, say 1600 micro steps/rev so one revolution on output of the 50:1 reducer will require 50x1600 = 80,000, so to get the pulses/degree will be 80,000/360 = 222.2222 Thats what it looks like to me. Al
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Yes it would be 1600 pulses for 1 rev. of the motor. I got as far as the 80,000 value but I wasn't sure if that was the value I had to enter into the "steps per units" box in Mach2 or if there was more calculations. It seemed way too high a value to be entered. Guess I was really missing an important part of the formula. I think part of the problem as I see now by how you figured that out is I kept on thinking in the way of, "steps per unit" when I should have been looking at it as "pulses per unit" or better yet "pulses per degree". Thank you Al. |
| 4020 4th axis problems | little bubba | Fadal | 3 | 06-13-2005 10:08 PM |
| 2 axis to 3 axis conversion | drembedded | Bridgeport and Hardinge Mills | 10 | 10-27-2004 12:32 PM |
| 5th even 6th axis? how does it work | ToMMY2ooo | General Metal Working Machines | 10 | 10-04-2004 04:58 PM |
| My Lathe project; might CNC it one day | Stevie | General Metal Working Machines | 86 | 06-21-2004 09:27 PM |
| 2.5-Axis vs 3-Axis | JamesBond | General Metal Working Machines | 6 | 07-26-2003 08:09 PM |
