| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
| I am using a cad software called Profili for making r/c model wing ribs. I have the unit measurements set to inches in the cad and also inthe Mach 2. When I send the dxf to mach 2 the parts are not cut at the samre size. For example I sent a 13 in. rib to mach and had to change the scale in mach to 10 times the size just to get it to cut a 6 in. rib. What am I doing wrong? What settings have I got wrong? Boy do I need help! |
| Hmmm... You might inspect the g-code and see if you can determine why. I doubt it has to do with demo vs pay-for. You might also ask Mach support folks. I am sure they want it to work for you (that way you will want to purchase their product ) |
| Most likely, the .dxf from profili is the wrong size. Can you post a sample we can look at?
| That's not a .dxf? Post the .dxf from Profili, and the g-code. Rename the g-code file so the extension is .txt and it should upload fine.
#10
This is the g-code as it comes from the program curare 5 test G70 G17 G90 G00X0.0000Y0.0000F12.0000 G67P0 G91 G67P0 G00X2.2930Y9.0544F12.0000 G68P0 G01X-0.3739Y-0.0439 G01X-0.3717Y-0.0598 G01X-0.0983Y-0.0185 G01X-0.0523Y-0.0185 G01X-0.0449Y-0.0326 G01X-0.0337Y-0.0440 G01X-0.0199Y-0.0518 G01X-0.0010Y-0.0045 G01X-0.0056Y-0.0897 G01X0.0012Y-0.0239 G01X0.0000Y-0.0749 G01X0.0075Y-0.0544 G01X0.0227Y-0.0500 G01X0.0361Y-0.0413 G01X0.0465Y-0.0292 G01X0.0248Y-0.0090 G01X0.3064Y-0.0563 G01X0.4617Y-0.0587 G01X0.4634Y-0.0428 G01X0.4646Y-0.0268 G01X0.0102Y-0.0004 G01X0.0486Y0.0059 G01X0.0441Y0.0212 G01X0.0350Y0.0342 G01X0.0222Y0.0436 G01X0.0062Y0.0300 G01X0.0000Y0.6067 G01X-0.0075Y0.0479 G01X-0.0226Y0.0429 G01X-0.0352Y0.0333 G01X-0.0441Y0.0201 G01X-0.0317Y0.0049 G01X-0.4701Y-0.0260 G01X-0.3888Y-0.0336 G67P0 G00X-1.3500Y-1.3623F12.0000 G68P0 G01X1.3000Y0.0000 G01X-0.0000Y0.2820 G01X0.4314Y-0.0374 G01X0.1721Y-0.0105 G01X0.6442Y-0.0268 G01X0.5814Y-0.0105 G01X0.0000Y0.2504 G01X0.2500Y0.0000 G01X0.0000Y-0.2500 G01X0.0000Y-0.0009 G01X0.6447Y0.0098 G01X0.1187Y0.0036 G01X0.9818Y0.0399 G01X0.9810Y0.0559 G01X0.9800Y0.0718 G01X0.7734Y0.0680 G01X1.2446Y0.1215 G01X0.3324Y0.0352 G01X-0.0000Y-0.6019 G01X1.3000Y0.0000 G01X0.0000Y0.7505 G01X0.0394Y0.0048 G01X0.0000Y0.4440 G01X-1.1987Y0.1385 G01X-1.2004Y0.1226 G01X-1.2019Y0.1067 G01X-1.1670Y0.0883 G01X-0.8070Y0.0488 G01X-0.8079Y0.0329 G01X-0.8083Y0.0169 G01X-0.2048Y0.0017 G01X-0.0000Y-0.2484 G01X-0.2500Y0.0000 G01X0.0000Y0.2492 G01X-0.1597Y-0.0003 G01X-0.5425Y-0.0108 G01X-0.5420Y-0.0268 G01X-0.5410Y-0.0428 G01X-0.1451Y-0.0142 G01X-0.3601Y-0.0456 G01X-0.3578Y-0.0614 G01X-0.2335Y-0.0489 G01X-0.2155Y-0.0561 G01X-0.2109Y-0.0714 G01X-0.1023Y-0.0409 G01X-0.1187Y-0.0591 G01X-0.1107Y-0.0729 G01X-0.0180Y-0.0138 G01X-0.0201Y-0.0171 G01X0.2932Y0.0000 G01X0.0000Y-0.3940 G01X-0.2922Y0.0000 G01X0.0756Y-0.0599 G01X0.0113Y-0.0073 G01X0.1459Y-0.0797 G01X0.1529Y-0.0653 G01X0.1176Y-0.0389 G01X0.0447Y-0.0135 G01X0.0000Y-0.5155 G67P0 G00X1.2876Y-0.7645F12.0000 G68P0 G01X-0.3714Y-0.0426 G01X-0.3693Y-0.0585 G01X-0.0554Y-0.0102 G01X-0.0508Y-0.0178 G01X-0.0434Y-0.0319 G01X-0.0322Y-0.0432 G01X-0.0181Y-0.0501 G01X-0.0050Y-0.0947 G01X0.0012Y-0.0225 G01X0.0000Y-0.0809 G01X0.0078Y-0.0530 G01X0.0230Y-0.0484 G01X0.0362Y-0.0395 G01X0.0462Y-0.0271 G01X0.0351Y-0.0101 G01X0.1756Y-0.0307 G01X0.4469Y-0.0593 G01X0.4488Y-0.0434 G01X0.4500Y-0.0274 G01X0.0709Y-0.0029 G01X0.0472Y0.0059 G01X0.0426Y0.0211 G01X0.0332Y0.0340 G01X0.0202Y0.0430 G01X0.0052Y0.0385 G01X0.0000Y0.5642 G01X-0.0076Y0.0467 G01X-0.0226Y0.0416 G01X-0.0351Y0.0317 G01X-0.0436Y0.0183 G01X-0.0252Y0.0035 G01X-0.4681Y-0.0256 G01X-0.3422Y-0.0289 G67P0 G00X-0.0799Y-1.0307F12.0000 G68P0 G01X0.0000Y-0.2845 G01X-1.2430Y-0.0048 G01X-0.0000Y0.5111 G01X-0.2060Y0.0720 G01X-0.0632Y0.0256 G01X-0.1100Y0.0528 G01X-0.1021Y0.0667 G01X-0.0244Y0.0190 G01X-0.0079Y0.0065 G01X0.2863Y-0.0000 G01X0.0000Y0.3940 G01X-0.2842Y0.0000 G01X0.0860Y0.0643 G01X0.0635Y0.0361 G01X0.1734Y0.0774 G01X0.1793Y0.0626 G01X0.0997Y0.0277 G01X0.3177Y0.0735 G01X0.3209Y0.0578 G01X0.2125Y0.0294 G01X0.4999Y0.0519 G01X0.5013Y0.0359 G01X0.5022Y0.0200 G01X0.1282Y0.0025 G01X0.4103Y0.0036 G01X0.0000Y-0.2484 G01X0.2500Y0.0000 G01X0.0000Y0.2483 G01X0.7592Y-0.0109 G01X0.7588Y-0.0269 G01X0.6921Y-0.0385 G01X1.1654Y-0.0830 G01X1.1641Y-0.0989 G01X1.1626Y-0.1149 G01X1.1610Y-0.1308 G01X0.1373Y-0.0165 G01X-0.0000Y-0.4387 G01X-0.0394Y-0.0047 G01X0.0000Y-0.6871 G01X-1.2430Y-0.0048 G01X-0.0000Y0.5516 G01X-1.2040Y-0.1195 G01X-1.1075Y-0.0958 G01X-0.8697Y-0.0648 G01X-0.8708Y-0.0489 G01X-0.8715Y-0.0329 G01X-0.6383Y-0.0139 G01X-0.1563Y-0.0019 G01X0.0000Y0.0007 G01X0.0000Y0.2500 G01X-0.2500Y0.0000 G01X-0.0000Y-0.2513 G01X-0.5713Y0.0102 G01X-0.5708Y0.0262 G01X-0.4803Y0.0345 G01X-0.1180Y0.0105 G67P0 G00X0.0166Y-1.0312F12.0000 G68P0 G01X-0.3671Y-0.0401 G01X-0.3650Y-0.0559 G01X-0.0161Y-0.0028 G01X-0.0496Y-0.0171 G01X-0.0422Y-0.0312 G01X-0.0310Y-0.0424 G01X-0.0158Y-0.0442 G01X-0.0020Y-0.1212 G01X0.0000Y-0.0876 G01X0.0076Y-0.0513 G01X0.0228Y-0.0466 G01X0.0358Y-0.0375 G01X0.0455Y-0.0249 G01X0.0290Y-0.0076 G01X0.4291Y-0.0619 G01X0.4311Y-0.0460 G01X0.4325Y-0.0301 G01X0.2039Y-0.0086 G01X0.0459Y0.0060 G01X0.0412Y0.0212 G01X0.0316Y0.0339 G01X0.0183Y0.0425 G01X0.0037Y0.0314 G01X0.0000Y0.5365 G01X-0.0077Y0.0455 G01X-0.0227Y0.0402 G01X-0.0349Y0.0301 G01X-0.0431Y0.0165 G01X-0.0188Y0.0023 G01X-0.4673Y-0.0251 G01X-0.2944Y-0.0241 G67P0 G00X-0.1098Y-1.2681F12.0000 G68P0 G01X-1.1861Y-0.0092 G01X-0.0000Y0.5071 G01X-0.2017Y0.0703 G01X-0.0551Y0.0222 G01X-0.1075Y0.0515 G01X-0.0997Y0.0654 G01X-0.0134Y0.0103 G01X0.2786Y0.0000 G01X0.0000Y0.3940 G01X-0.2771Y0.0000 G01X0.0857Y0.0605 G01X0.0448Y0.0245 G01X0.1700Y0.0752 G01X0.1758Y0.0603 G01X0.0859Y0.0235 G01X0.3114Y0.0714 G01X0.3146Y0.0557 G01X0.1862Y0.0254 G01X0.4900Y0.0503 G01X0.4913Y0.0344 G01X0.4922Y0.0184 G01X0.0834Y0.0015 G01X0.3826Y0.0034 G01X0.0000Y-0.2484 G01X0.2500Y0.0000 G01X0.0000Y0.2484 G01X0.7440Y-0.0109 G01X0.7436Y-0.0269 G01X0.6186Y-0.0346 G01X1.1407Y-0.0809 G01X1.1394Y-0.0968 G01X1.1380Y-0.1128 G01X1.0807Y-0.1220 G01X-0.0000Y-0.4330 G01X-0.0394Y-0.0047 G01X-0.0000Y-0.6278 G01X-1.1861Y-0.0092 G01X-0.0000Y0.5050 G01X-1.1844Y-0.1157 G01X-0.6658Y-0.0580 G01X-0.8733Y-0.0681 G01X-0.8744Y-0.0521 G01X-0.8752Y-0.0362 G01X-0.7597Y-0.0184 G01X-0.1465Y-0.0018 G01X0.0000Y0.0007 G01X0.0000Y0.2500 G01X-0.2500Y0.0000 G01X0.0000Y-0.2512 G01X-0.5599Y0.0104 G01X-0.5593Y0.0264 G01X-0.4201Y0.0304 G01X-0.1126Y0.0099 G01X0.0000Y-0.2876 G67P0 G00X0.0467Y-0.7285F12.0000 G68P0 G01X-0.3716Y-0.0402 G01X-0.3288Y-0.0491 G01X-0.0479Y-0.0163 G01X-0.0405Y-0.0304 G01X-0.0291Y-0.0415 G01X-0.0130Y-0.0380 G01X-0.0029Y-0.1143 G01X0.0005Y-0.0091 G01X0.0000Y-0.0918 G01X0.0077Y-0.0496 G01X0.0229Y-0.0447 G01X0.0357Y-0.0353 G01X0.0449Y-0.0224 G01X0.0217Y-0.0051 G01X0.4250Y-0.0584 G01X0.4269Y-0.0425 G01X0.4282Y-0.0265 G01X0.1208Y-0.0046 G01X0.0446Y0.0062 G01X0.0397Y0.0213 G01X0.0299Y0.0337 G01X0.0163Y0.0420 G01X0.0024Y0.0245 G01X0.0000Y0.5088 G01X-0.0078Y0.0443 G01X-0.0227Y0.0388 G01X-0.0348Y0.0285 G01X-0.0425Y0.0146 G01X-0.0124Y0.0013 G01X-0.4404Y-0.0226 G01X-0.1894Y-0.0147 G01X-0.0833Y-0.0068 G67P0 G00X1.4236Y-1.0027F12.0000 G68P0 G01X-0.0000Y0.2508 G01X0.2500Y0.0000 G01X-0.0000Y-0.2500 G01X-0.0000Y-0.0010 G01X0.3940Y0.0057 G01X0.8908Y0.0297 G01X0.8901Y0.0456 G01X0.8891Y0.0616 G01X0.5577Y0.0468 G01X1.1671Y0.1086 G01X0.2519Y0.0255 G01X-0.0000Y-0.4614 G01X1.1291Y0.0131 G01X-0.0000Y0.5720 G01X0.0394Y0.0046 G01X0.0000Y0.4270 G01X-1.1121Y0.1230 G01X-1.1138Y0.1071 G01X-1.1152Y0.0912 G01X-0.8660Y0.0597 G01X-0.7275Y0.0388 G01X-0.7282Y0.0229 G01X-0.5465Y0.0066 G01X-0.0000Y-0.2485 G01X-0.2500Y0.0000 G01X0.0000Y0.2485 G01X-0.3550Y-0.0032 G01X-0.4627Y-0.0136 G01X-0.4619Y-0.0295 G01X-0.4606Y-0.0455 G01X-0.2728Y-0.0345 G01X-0.2800Y-0.0474 G01X-0.2769Y-0.0630 G01X-0.1612Y-0.0444 G01X-0.1473Y-0.0504 G01X-0.1414Y-0.0653 G01X-0.0730Y-0.0410 G01X-0.0409Y-0.0281 G01X0.2711Y0.0000 G01X0.0000Y-0.3940 G01X-0.2691Y0.0000 G01X0.1112Y-0.0698 G01X0.1189Y-0.0558 G01X0.0616Y-0.0223 G01X0.1478Y-0.0481 G01X0.0000Y-0.5030 G01X1.1291Y0.0131 G01X-0.0000Y0.2902 G01X0.3114Y-0.0260 G01X0.5765Y-0.0307 G01X0.5771Y-0.0147 G01X0.0983Y-0.0009 G67P0 |
#11
| I need to see BOTH the gcode, and the .dxf used to create the code
| Need Help!- mach 2 program scale | vicsrc | Mach Software (ArtSoft software) | 4 | 12-16-2008 12:39 PM |
| Need to make scale tire mold for 1/6 scale car | thuffner3 | Moldmaking | 2 | 04-29-2008 12:57 AM |
| Confused: Mach Turn, Mach Mill, Mach 2/3 ? | CanSir | Mach Software (ArtSoft software) | 5 | 02-16-2007 04:41 AM |
| Mach 2 loosing brains after loading gcode (Scale gets way off) Any Ideas | InventorJohn | Mach Mill | 6 | 01-12-2007 10:42 AM |
| Mach 2 DXF import not to scale | barnon | Mach Plasma / Laser | 5 | 04-03-2006 11:19 AM |
