| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
| Hello Todd, I would suggest you to use Windows XP for your Mach3. Be sure to get the latest Windows Updates! But in order to reduce the PIII Processor's calculation, I would suggest you to get an external VGA Graphic's Card. Do you mind posting your PIII Computer specifications, eg. cpu mhz, ram, harddisk space, motherboard brand used?
__________________ "I will not let you regret knowing me." |
| Get the latest updates and then take it off the internet until you feel the need for more updates. I have run my dspmc with a fresh install of Vista on my laptop, because I wanted to get rid of the bloatware, and it runs real smooth. I have not run a 1hr long part yet, but I will be doing some cutting real soon. If you get the urge to try Vista, you can install it from any Vista disk, and it will run for 30 days, even without the instal code. I am currently running win2k on my dspmc as it was what I had at the time. Mike
__________________ Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out. |
| Hi Todd, In addition to Mike(TOTALLYRC's post, an external signal generator such as DSPMC will lower your CPU's handling, putting your CPU in a much more relaxed, mode, as well as reduced CPU heating. You can also try SmoothSteppers, http://www.warp9td.com/ ( I have not tried it before) but it's more affordable, comparing do DSPMC. But DSPMC has something special called closed loop, isn't it, Mike? Mike, would you care to explain more about DSPMC's closed loop feature Sunmixed
| Turning off the toolpath display will cut CPU usage in half, or even more. This can make a huge difference on a slow machine.
I don't want to hijack Todd's thread. If you want more info on my DSPMC installation, see my build thread. http://www.cnczone.com/forums/showthread.php?t=66994 Ger21 is exaclty right, especially if your pIII is below 1 GHZ
Thanks for the responses, I just was thinking that WIN 2000 would be a good bare bones OS to run. I plan on running the DSPMC device (thanks Mike) for my interface device. I was just thinking that I wanted to keep the K.I.S.S. methodolgy intact. And remember "We say Merry Chirstmas around here." |
| Tags |
| computer, mach 3, operating system, retrofit |
| Need Help!- CNC Software and operating system | jeffmorris | General CNC (Mill and Lathe) Control Software (NC) | 15 | 03-06-2008 03:33 PM |
| Best Pc Operating System to run CNC designs. | SpeedsCustom | General CNC (Mill and Lathe) Control Software (NC) | 48 | 12-24-2007 10:23 AM |
| Installing Operating system | millman52 | General Electronics Discussion | 8 | 10-07-2007 10:38 PM |
| CNC linux operating system | piglete2000 | AjaxCNC Control Products | 4 | 06-23-2005 08:55 AM |
| Choice of operating system | HuFlungDung | CamSoft Products | 17 | 06-11-2004 11:25 PM |
