Old 12-21-2008, 07:34 PM
Byron79 is on a distinguished road
Angry use encoder as dro ??????
under ports and pins i setup an encoder input, now when i go and turn that encoder by hand it should see that i moved the axis but the dros on the pgm run screen just sit there???????????? Anyone familiar with this?? TNX
Old 12-21-2008, 07:50 PM
ger21's Avatar
You need to add a DRO to the screen for the encoder. The regular DRO's won't show the encoder's movement.
Old 12-21-2008, 08:06 PM
is there a screen that already has them???
Old 12-21-2008, 08:20 PM
ger21's Avatar
Not sure, but I don't think so.
Old 12-23-2008, 08:51 PM
sunmix is on a distinguished road
Hi Bryon, what encoder model are you using? What version of Mach3 are you using? I have experimented with a simple 200 line encoder and it never works till now. I think it's the encoder's fault. It's from CNC4PC.
To really confirm that your encoder is recieving, you should find a DRO called Encoder Counts, and, whenever you turn your encoder, the count should "Count". Oh yeah, you also have to hook up the encoder voltage ground with the parallel port's ground only you can get it working fine.
Old 12-24-2008, 06:47 AM
H.O H.O is offline
H.O is on a distinguished road
The Encoder DRO's are located on the Settings page of the standard 1024.set screen-set file. If you click Settings you'll see a page with an ugly green background and in the middle of it there is the Encoder DROs.
If you want them to be in any other place then use the Screendesigner to add them to the screen of your choice.
FYI the numbers of the DROs are 29,30 and 31 for X, Y and Z respectively.
/Henrik.
encoder 250 or 500 ppr? omarfarrar Servo Motors and Drives 8 08-06-2008 11:37 PM
Encoder ? Ken_Shea General Electronics Discussion 0 09-22-2007 06:52 PM
How to tell if my motor is Pulse encoder or quadrature encoder? Darc Servo Motors and Drives 0 07-22-2005 03:51 AM
What is an Encoder ? ynneb FAQ of CNC Machine building 0 08-17-2004 06:02 AM
Encoder ty1295 Servo Motors and Drives 4 05-27-2004 02:50 PM
