Old 12-14-2008, 12:00 PM
Mephysto's Avatar
Mephysto is on a distinguished road
Problems with auto tool zero
Hi there,
I'm using this script:
Zmove = 10 'amount the tool will move down to hit the probe
Zpos = GetDRO(2)
Tool = GetDRO (24)
ZOffset = 33.32 'enter height of probe here
OldZpos = Zpos
ZPos = Zpos - ZMove
Code "G31 Z" & ZPos & " F40.0"
While IsMoving()
Wend
Zpos = GetVar (2002)
If Zpos = OldZpos - ZMove Then
responce = MsgBox ("ERROR! The tool did not hit the probe and DRO was not set" , 4 , "Probe ERROR!" )
Else
SetDRO (2,ZOffset)
End If
Code "G00 G53 Z-.1"
couple of times, after touching the probe, Z proceedes downward instead of upward causing "injuries" to the blade. Why does it happen?? Where is the the mistake? Help me please...
Old 12-14-2008, 12:27 PM
BobMorside is on a distinguished road
I'm guessing its the G53 that is causing you problems.
Since it is referencing machine coordinates while your DRO's are showing whatever coordinate system you are using when the routine started
Old 12-14-2008, 12:30 PM
Mephysto's Avatar
So how can I change this script in order not to be scare every time I want to zero my tool?
Old 12-14-2008, 06:43 PM
Shinosky is on a distinguished road
I can't explain why the machine continues down after the G53 but try adding a pause statement after the SetDRO command.
The machine is executing the rapid move before the DRO is fully updated.
Try something like this..
Code "G4 P0.25" 'Pause for Dro to update
The P0.25 is a 1/4 second pause
Here is a complete script that others are using with much success.
Of course you would need to change some of the values to suit your needs.
CurrentFeed = GetOemDRO(818) 'Get the current feedrate to return to later
PlateThickness = GetUserDRO(1151) 'Z-plate thickness DRO
If GetOemLed (825)=0 Then 'Check to see if the probe is already grounded or faulty
DoOEMButton (1010) 'zero the Z axis so the probe move will start from here
Code "G4 P2" ' this delay gives me time to get from computer to hold probe in place
Code "G31Z-20 F100" 'probing move, can set the feed rate here as well as how far to move
While IsMoving() 'wait while it happens
Wend
ZProbePos = GetVar(2002) 'get the axact point the probe was hit
Code "G0 Z" &ZProbePos 'go back to that point, always a very small amount of overrun
While IsMoving ()
Wend
Call SetDro (2, PlateThickness) 'set the Z axis DRO to whatever is set as plate thickness
Code "G4 P0.25" 'Pause for Dro to update.
Code "G0 Z20" 'put the Z retract height you want here
Code "(Z axis is now zeroed)" 'puts this message in the status bar
Code "F" &CurrentFeed 'Returns to prior feed rate
Else
Code "(Z-Plate is grounded, check connection and try again)" 'this goes in the status bar if applicable
Exit Sub
End If
Auto tool zero wildcat Mach Mill 30 10-08-2010 11:03 AM
Need help badly Auto tool Zero native34 General Electronics Discussion 12 09-22-2008 04:56 PM
Auto Tool Zero VB problem Normsthename Mach Wizards, Macros, & Addons 0 11-23-2007 10:15 AM
Auto Tool Zero Moondog Machines running Mach Software 13 12-22-2006 06:02 PM
Auto cut problems harvard5 BobCad-Cam 2 05-06-2006 10:23 AM
