Old 11-30-2008, 04:19 PM
Rich05 is on a distinguished road
Mach issue with my mill
A new problem has appeared. When the spindle is running the keyboard and mouse become scrambled. They give random inputs when I press on the keys. This does not happen if the spindle is not turning. It clears up as soon as spindle stops turning. Any ideas? thanks R.
Old 11-30-2008, 04:29 PM
Al_The_Man's Avatar
Most likely a Grounding issue, if your PC is desktop or tower, the PC power supply common is at the same potential as your spindle (neutral), if it is an AC motor or DC SCR controlled from the 120v mains supply.
I would guess that the majority of 'noise' problems is the lack of proper grounding of the parallel port and the service ground to a common point in order to create zero potential difference between the two.
Old 11-30-2008, 04:42 PM
thanks Al. As allways you are a great help. Any suggestions on how to beat the grounding issue?
Old 11-30-2008, 05:00 PM
Al_The_Man's Avatar
First off I would not rely on the MB ground screws, I would take the common where it leaves the Parallel port and take it to a common ground point where the service ground is also connected.
The spindle motor frame ground would also go back to this point.
Mach 3 issue - possbily arc gcode related fseger Mach Software (ArtSoft software) 2 05-28-2008 05:35 PM
Multiple spindles on Mach 3 mill jomijen Mach Mill 4 12-21-2007 06:45 AM
Mach 3 mill on a kuhlmann p20c ? mocs Machines running Mach Software 0 11-08-2007 12:34 PM
Confused: Mach Turn, Mach Mill, Mach 2/3 ? CanSir Mach Software (ArtSoft software) 5 02-16-2007 04:41 AM
Help with selector switch wiring issue (***actually a motor issue***) BEDFORD Industrial Hobbies (Support forum) 7 04-07-2006 03:19 PM
