| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
do you have to enable fro not rapid but straight fro in mach3 the f10 and f11 button only change the dro but not the actual speed i did a quick search in the forum but all i found where people asking about rapid fro.
__________________ The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne |
| What version are you using? It works in 2.63 and 3.42.020, although it seems to work a little quicker in 2.63. Do you have the box checked to lock them together in General config?
| ok so if its check then fro wont go over 100% because rapid fro is allready at 100% is that it 3.42.020 edit k thats kinda weird i have uncheck the lock between the rfro and the fro now it work but in order for it to work i have to do a feed hold and cycle start againedit2: ok unchecking the feed queu something solved the problem finally i am close to getting a machine that operates properly
__________________ The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne Last edited by ataxy; 11-28-2008 at 06:44 PM. |
| Lock out feed rate override | Daves 41 | Haas Mills | 21 | 04-21-2008 05:14 PM |
| Need Help!- Feed rate Ovverride also Increases rapid rate. | Korellibopper | Machines running Mach Software | 1 | 01-30-2008 05:37 PM |
| feed override keys | elpete0068 | Mach Wizards, Macros, & Addons | 2 | 01-16-2008 01:44 AM |
| Mach 3 & Feed Rate Override | aus-newb | Mach Lathe | 1 | 11-21-2005 06:56 PM |
| Feed Override | SCOJEN | DIY-CNC Router Table Machines | 0 | 01-24-2005 12:56 PM |
