| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
Hi To keep motors from overheating, I need them to "enable" only when in use. My driver has this "enable" wiring but I do not know how to set them up in Mach3. Thanks |
| The motors should not overheat simply from being held unless there is something wrong with the motor current level given by the driver. If I understand correctly (have not been using Mach3 long), the Enable line does NOT enable drive current at all. Rather, it enabled the driver to respond to Mach3 signals. This is because when you need to cycle power on the computer, the parallel port will "glitch" and make the driver move steps. This will make mach3 lose its understanding of the exact absolute position of the machine, and if the machine is in a critical position such as on the surface of the work it may damage the tool. IIRC the Enable is a recognizable pulsed signal, since the Enable signal may also go to an "active" level when power is cycled. |
| you can use a relay board to run your supply power through , then you can use an optional M code to turn the supply on and off http://cgi.ebay.com/CNC-PLASMA-ROUTE...713.m153.l1262 i bought his relays breakout board and it worked great
__________________ A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org |
Wire your enable wires to the parallel port, and configure the enable pins in "Ports and Pins" sceen.
| Bridgeport stepper motors mach 3 setup? | wyobmf | Bridgeport and Hardinge Mills | 14 | 12-29-2008 08:15 AM |
| cant get mach turn to run | panaceabea | Mach Software (ArtSoft software) | 0 | 12-10-2007 07:56 AM |
| Motors turn in Kcam, but not Mach. Any ideas? | cephjedi | Mach Mill | 4 | 04-16-2007 04:10 PM |
| Confused: Mach Turn, Mach Mill, Mach 2/3 ? | CanSir | Mach Software (ArtSoft software) | 5 | 02-16-2007 04:41 AM |
| stepper motors turn only one direction | Mike Boarman | General Electronics Discussion | 7 | 11-24-2006 04:43 PM |
