| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
I am new to the cnc scene. I recently finished building my cnc taig machine, powered by a xylotex board and 240oz/in steppers. Today I configured everything,port pins, motor tuning etc. and the first tests went well. Using mach1 I can jog all axis, but I hit problems when I try to get it to run from code. I exported the nc .iso file from deskproto and imported it into mach1. When I run the sequence all I can here is the motors groaning and the spindles twitch. I got it to start but then the motors kept locking up after a few lines and then they didnt move at all. I have fiddled with everything I can think of, but nothing has any effect. Can anyone think what might be causing this? Thanks. |
| What software are you using to generate the gcode and are you using the Mach1/2 Post for that sw package?
Sorry, my bad, did not read the post completely. I just have not seen a Mach1/2 Post for DeakProto. I thought it was a Post problem.
| Turns out it was partly deskprotos fault. In the milling machine settings it was set to 30mm/min travel. That coupled with the fact I had my spr wrong made it really slow! In the end I worked out that I had a 20tpi lead screw, so in 1/8th step mode I needed 32000 steps per inch I just let the program caluclate the mm's. |
| looking for g code 3d from bobcadcam or simmilar for indexer lpt v5 with g code soft | troyswood | Ability Systems - LPT Indexer and G-Code | 2 | 12-24-2006 10:21 PM |
| parametric programming | Karl_T | CamSoft Products | 21 | 05-24-2005 03:58 PM |
| running direction problems | gv71 | Yeager Automation | 1 | 10-27-2004 08:19 AM |
| Accuracy problems | i228208 | General CAM Discussion | 26 | 05-30-2004 02:31 PM |
| Getting The Most Out of CNCzone's Posting Features | CNCadmin | CNCzone.com FAQ | 0 | 03-02-2003 12:08 AM |
