Results 1 to 3 of 3
Thread: Mach 3 LazyCam G Code
    Nov 2007
    UK
    Unhappy Mach 3 LazyCam G Code
    I am new to Mach 3 and on a learning curve. I would like advice on following :-
    I generate a cross shape profil which comprises a number of straight lines and tangential arcs.
    I save this in AutoCAD as a Dxf file.
    I then open it via Lazycam in Mach 3
    I then generate the g code in Mach 3
    Everthing goes OK and the file runs, but I want the milling cutter to progress round the profile in a continuous cut. What I get machines say 4 arcs then moves and machines straight parts etc.
    Although I could edit the G code, I feel I must be missing a quicker solution ?
    Any guidance appeciated.
    Mar 2003
    Shelby Twp, MI....USA
    try joining all the lines and arcs in AutoCAD into 1 continuous polyline. Use the PEDIT command.
    Nov 2007
    UK
    Thumbs up AutoCAD pline - Lazycam - G Code
    Gerry,
    Thanks for you help. I used the "join" option in PEDIT and it fixed the problem.
    The G code generated was exactly what I wanted.
    Thanks for your help.
    Geoff
  1. Help! need someone to help w/ some mach 3 g code programming
    By sconklin in forum Mach Wizards, Macros, & Addons
    Last Post: 06-30-2010, 08:53 PM
  2. G code / mach 3 question
    By contractdesign in forum Bridgeport and Hardinge Mills
    Last Post: 11-07-2007, 09:41 AM
  3. dxf to g code coverter for mach 3
    By rbyrer in forum General Metalwork Discussion
    Last Post: 06-28-2007, 07:33 PM
  4. g code and Mach
    By andrewbishop66 in forum Mach Mill
    Last Post: 03-15-2007, 08:04 PM
  5. lazycam
    By timmyb199 in forum Mach Software (ArtSoft software)
    Last Post: 09-27-2006, 11:30 AM
