Richster,
I checked your code out in Vericut. No problems that I could see except for the codes I have added to your program. You should be using the G54 command for your fixture offset (the distance from the machine home to the part zero on the table.) Also you should take advantange of the G43 height offset for your tools.
This is my version of your code:
(Cutter compensation problems)
(Richster program)
G21 (***inch/mm select***)
M6 T1
G0 G90 G54 X0 Y0 (***Fixture offset #1 here***)
G43 H1 Z10 (***tool #1 height offset here***)
G42
G0 X10 Y0 (comp being applied here)
G0 X20 Y0 (comp is now applied)
G1 Z-1
G1 X50
G1 Y50
G1 X20
G1 Y0
G1 Z0
G40
G0 X20 Y-10 (comp removed here)
G0 X20 Y-20 (comp is now removed)
G0 X0 Y0
M30
Vericut Verification photo of this code:
LinkBack URL
About LinkBacks
