| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
OK...so I have breezed over the instructions...WOW. first my jog up/down are switched...help does mach2 convert dxf to g-code within the software? could someone please give me a brief walk thru on: input g-code/dxf, basic set-up, limits....one button to start the cutting proccess.... I know its much and everyone has said to read the instructions but HELP!!!! thanks.pierre |
| The online manual currently is way behind where the software is at, which probably isn't helping you any. There should be a new up to date manual in the next 2 weeks or so that should be much more helpful to you. Mach2 can create gcode from .dxf, but someone else will have to explain it to ya.
| I hated it when I was told "Read the manual" too. In the end I read a bit, experimented a bit, and read a bit more. If you read the manual first, it will make very little sence, especially if you are new to the many terms that it refers to. I suggest to print the maunual out and staple it into chapters. Read only the chapters that relate to your current issues. The next thing to do is download my very simple screen and just use that first. It is a lot less cluttered with confusing controls. After a time you can add other controls as you need them. http://cnczone.com/modules.php?name...p=visit&lid=195 What control cards are you using? |
I'm getting "do not have permission to access this page" when I click on the link. |
| try this link- http://cnczone.com/modules.php?name=...nkinfo&lid=179
__________________ Thank You, Paul G Site Owner-Webmaster- Administrator www.rfqwork.com www.cnczone.com www.welderzone.com |
| Mach2 remembering position after shutdown..how does it know | Moondog | Mach Software (ArtSoft software) | 10 | 02-14-2005 09:56 AM |
| Windows XP or Windows 2000 better with Mach2 | Beezer | Mach Software (ArtSoft software) | 2 | 10-18-2004 11:08 AM |
| Mach2 Faro Arm Inverse Kinematics | vacpress | General CAM Discussion | 7 | 05-28-2004 10:14 AM |
| G Code and Mach2 | InventIt | DIY-CNC Router Table Machines | 8 | 03-13-2004 02:46 PM |
| mach2 versus EMC | georgebarr | Mach Software (ArtSoft software) | 3 | 02-22-2004 12:32 PM |
