Old 08-21-2004, 10:17 PM
ynneb's Avatar
Moderator
ynneb is on a distinguished road
Mach2 & Rutex relay board.
Up till now I have been turning my spindle on and off manually.
I havent connected the spindle to the Rutex relay board yet.
I have tried to get the relays to respond to Mach2 input but cant hear them click in or out. I have tried to configure the relay board to respond to Mach2's input but have had not luck.
In the Rutex pdf concerning the relay board it says that I need to use pin 14 of the printer cable and use port C./1 . What does C./1 mean.
Has any one else successfully enabled spindle control using the relay board?
Old 08-22-2004, 02:50 PM
svenakela is on a distinguished road
Not yet, I have my board somewhere on the way to Sweden right now...
There is a document describing the schematic at the rutex web page, at http://www.rutex.com/pdf/R990IO.pdf where you hopefully can find the answer. Any possibilty that some shortcut jumper is left somewhere after tuning the drives that maybe takes over a parallel port pin?
Cheers,
Sven
Mill Post: MC9 to Mach2...I'm using a Xylotex Board? EPM Screen Layouts, Post Processors & Misc 7 04-20-2005 10:05 PM
Mach2 configuration for Rutex R90H Left Mach Software (ArtSoft software) 0 01-20-2005 04:24 PM
E-Stop Hard Wire and to Software? Sanghera General Electronics Discussion 20 10-30-2004 12:22 AM
Gecko vs Rutex samualt Gecko Drives 20 10-21-2004 02:48 AM
Mach2 and Rutex ynneb Mach Software (ArtSoft software) 20 03-31-2004 03:37 PM
