Old 08-18-2004, 12:22 AM
InventIt is on a distinguished road
Limits and Mach2 ?
Where is the button in Mach2 that makes the axis move to the the limit switches for referencing? I spent an hour trying to figure this out. I know I must be overlooking something simple. I read through the manual but didn't find it.
Maybe I just need sleep
Old 08-18-2004, 09:24 AM
kong is on a distinguished road
It is on the "Positioning" screen as "Ref All" - circled, top left in the screeny
Name:	Untitled-1 copy.jpg‎
Old 08-18-2004, 10:48 AM
Ok, I must need to do something else to make this work? When I hit the 'Ref All' button nothing happens to the machine. The DRO's zero out but the machine did not move to the limit switches. Is there a check box to enable/setup the limits? What am I missing?
Old 08-18-2004, 10:56 AM
Yep, you will need to check your config. Erm, it will be different with each version of MAch2! Try the input pins and input setup in the "ports and pinsŁ section of the config menu, then, you may also have a seperate section called "homing" in there to adjust. There should also be a tick-box *somewhere* to tell Mach2 to use the limit switches as home switches, if that is what you are doing. Also, Ref-All will ref all axis simultaneously, so your switches will need to be wired on seperate inputs, or they will all be triggered once one switch is hit. If you have this problem, you will need to ref one axis at a time, in which case, the buttons are hidden in the screen designer section and you will need to edit your screen to add the buttons manually. Few!
Old 08-18-2004, 04:57 PM
Thank you very much. I'll check all those.
Old 08-18-2004, 07:53 PM
Wuhooooo!!! GOT IT WORKING. Man that is SWEET! Moves to the switch then backs off it all by it's self!!!
Had to configure the pins in the ports/pins screen.
BTW, unless the box is checked for Home X, Home Y, or Home Z etc (in the ports/pins screen), Mach2 won't move the machine on a Ref All button push. And only the axis that are setup to home will move.
Thanks Kong
Mach2 ROCKS!!
Limit and home switches EMC and Mach2? ESjaavik LinuxCNC (formerly EMC2) 4 09-29-2008 11:39 AM
mach2 LIMIT SWITCH end of stroke reliese? mike10 Mach Software (ArtSoft software) 5 04-25-2005 11:48 AM
HELP....new to MACh2 fattuna Mach Software (ArtSoft software) 6 09-17-2004 01:07 AM
Wiring - What gauge for PS vs Limits vs Other AJ_Mac2001 General Electronics Discussion 10 01-31-2004 12:13 PM
Limits, homing, and relay switches Bloy2004 General Electronics Discussion 3 11-24-2003 06:17 PM
