Results 1 to 3 of 3
Thread: Mach Locks Up
    Jan 2006
    Mach Locks Up
    I have just recently updated to the newest version of Mach3. I am using a Siig jj-p00112-s6 parallel port card and a plain ole winford breakout board.
    When I use the built in parallel port, I am unable to get Mach3 to run the motors and everything else by just setting it up as it should be through Mach3Mill profile. IE pins 2-7 for motors, etc. When I do that nothing happens. The motors dont move and the limits wont work, etc. If I install a different profile from my old breakout board everything will work except my limit switches.
    To get them to work, I need to use the siig parallel port card. Now the problem is, when I reinstalled mach3 and reinstalled the CandCNC profile, mach3 will lock up when I try to use the siig breakout board. It will lock up immediately after I change the port address. The port address I am inputting is 0x007. If I go back to using the built in parallel port, address 378, the motors work fine, but my optical limits wont work at all. I know the limits work because I can check them using a voltmeter, but when plugged in to the port, mach cant see them when they trip. So, per the recommendation from the limit manufacturer, I use the Siig card. But now, after the reinstall, when I try use the card port address, mach, and the whole computer, lock up.
    So any suggestions. I have purchased a new siig card just in case that was the problem but that will be a week till it gets here.
    Mar 2003
    Shelby Twp, MI....USA
    Try using 0007, don't type the "x".
    Jan 2006
    Tried it and nothing. Still locks up. If i just use the Mach3Mill profile and not the CandCNC profile, it will take the siig port address but nothing happens. No input or output. Thank you though
  1. g203v locks motor, but won't jog....
    By mxpro32 in forum Gecko Drives
    Last Post: 12-15-2007, 07:18 PM
  2. PC locks up sending to Mazak
    By xr135 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-20-2006, 09:48 AM
  3. Mastercam locks up with Mazak
    By xr135 in forum Post Processors for MC
    Last Post: 06-20-2006, 08:44 AM
  4. PC locks up with masterCam/Mazak
    By xr135 in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 06-19-2006, 10:18 AM
  5. G320 Locks & Sings, but NO Step
    By mikkojay in forum Gecko Drives
    Last Post: 04-01-2006, 04:37 PM
