Results 1 to 3 of 3
Thread: Mach 3 Jog movement question
    Registered Drakkn's Avatar
    Sep 2006
    England
    Question Mach 3 Jog movement question
    I have built a machine with 3 axis and running mach3
    when you jog the x and y axis using the + button ,the x and y move towards the stepper motors,
    when you jog the z axis using the + button the travel is away from the stepper motor .How can i sort out this problem - the stepper motor on the z axis is the opposite way round to the other motors.
    Is there a software setup solution
    Drakkn Custom Shop http://www.cbgyorkshire.co.uk
    Gold Member mxtras's Avatar
    May 2005
    Does it act right when you run a program? If you set zero and command Z-1, does it move down or up? You can change the direction in the ports and pins or motor set-up screen - select reverse. I don't have a copy of MACH in front of me so I can't direct you in a step by step manner. Sorry. I had a similar issue when I set up my mill.
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
    Sep 2006
    England
    Will check out - ports and pins - Think I know where that is in the software - Its all very new to me at the moment.So close to finishing now.eg neez to sort out some longer cables for y and z axis and a mount for the router plus a bit - then can go cutting hopefully
  1. I know it's a Mach 3 question....
    By Smitty911 in forum Benchtop Machines
    Last Post: 11-30-2007, 08:16 PM
  2. New W.XP and Mach 2.48 no movement
    By hugo carradini in forum Machines running Mach Software
    Last Post: 10-14-2007, 12:44 PM
  3. Mach 2 Program Question?
    By qsacracer in forum Mach Software (ArtSoft software)
    Last Post: 11-17-2004, 11:39 AM
  4. Mach question
    By cncman2 in forum Mach Software (ArtSoft software)
    Last Post: 03-31-2003, 01:42 PM
  5. Mach 1 question
    By CNCadmin in forum Mach Software (ArtSoft software)
    Last Post: 03-31-2003, 01:36 PM
