Old 08-14-2007, 11:34 AM
Rich05 is on a distinguished road
seccond PARALLEL port?
We installed a seccond breakout board to control the limit switches on the mill. using mach3 1.84 software. Need to use a second PC port for it. We enabled the port but mach3 basically locks up the mill when this is done.
tried to make sure have the correct I/O hex address for LPT3 however that also, did not work.
tried a starteck and wiseland pci to parel. cards out thinking of trying a dual sigII now.
can anyone advise how to get the second LPT/Par. port going with mach? seems it is conflicting pretty badly.
Old 08-14-2007, 09:31 PM
txcowdog's Avatar
Gold Member
txcowdog is on a distinguished road
Look at this page http://www.beyondlogic.org/spp/parallel.htm and check the section labeled "Port Addresses". You will see that the real LPT1 address is 3BCh. I have found in the past that when I install a second LPT port, I have to set the new card as 3BCh and that becomes LPT1 and then the port on the motherboard becomes LPT2.
C++, Win XP, Parallel Port Zumba Coding 7 03-29-2012 01:12 PM
Where's the parallel port? cdlenterprises Mastercam 23 01-20-2007 05:23 PM
Second parallel port? essa LinuxCNC (formerly EMC2) 11 04-12-2006 02:18 AM
Parallel port Aldoseri BobCad-Cam 11 03-13-2006 10:10 AM
Parallel Port Shanghyd Computers and Networking 1 11-22-2004 11:56 AM
