Old 08-08-2007, 10:04 AM
Drakkn's Avatar
Drakkn is on a distinguished road
Question Mach 3 driver config file
I have a demo of mach 3 - I would like to know where to put the config file that I received with my controller card - Or is there a way to set it up.
Sorry if this is the wrong place for this question
Drakkn Guitars http://www.uk-guitarshop.co.uk
Old 08-08-2007, 10:12 AM
ger21's Avatar
If it's an .xml file, just drop it in the Mach3 folder. You'll need to start Mach3 with that profile. Instructions to do that can be found in the manual.
Old 08-08-2007, 10:44 AM
Drakkn's Avatar
Smile
Thanks it is an xml file - great support - very quick answer
Old 08-10-2007, 03:42 AM
Drakkn's Avatar
Thanks that worked
How do you set up your machines work area in mach3
and is there a manual i can download
Old 08-10-2007, 10:17 AM
ger21's Avatar
You can get the manual at www.machsupport.com
Old 08-10-2007, 01:28 PM
tauntdesigns's Avatar
tauntdesigns is on a distinguished road
Here's a link to some video tutorials on the mach site:
http://www.artsoftcontrols.com/artsoft/videos.htm
Good luck,
Jack
Walking is highly over-rated
Old 08-10-2007, 02:17 PM
Drakkn's Avatar
cheers - got the manual will attempt to inwardly digest - then make my z axis work - think the stepper motor is not much good.
Config/State only for licensed Mach 3?? Mr. Technical Mach Mill 3 07-25-2007 08:34 PM
config settings for mach 2 fidia General CNC (Mill and Lathe) Control Software (NC) 3 07-04-2007 05:18 AM
Confused in Mach 2 enable pins config,it's mapping to XYZ or not? szcharle General CNC (Mill and Lathe) Control Software (NC) 0 02-15-2007 05:23 AM
Mach 3 config?? HELP ty1295 Servo Drives 3 02-20-2006 12:20 PM
Mach 2 config questions randyf1965 Mach Software (ArtSoft software) 1 04-19-2005 10:05 PM
