Results 1 to 3 of 3
Thread: Bad Weather Shut Down
    Feb 2005
    It is the time of year that bad thunderstorms are rolling through our area. We are concerned with damage to our units from a lightning strike as well as loss of machining time. Is there a way to shut down the unit and then restart at the previous point in the program? We are running mold contouring programs, usally one of a kind. Can't find anything in the Mach 2 manual. Any help or direction would be appreciated.
    JohnD
    Mar 2003
    Shelby Twp, MI....USA
    If you pause or stop it and know where your at, you can use run from here when restarting.
    May 2005
    us
    In a thunderstorm prone area I would have every computer hooked up to a UPS. For one thing, they provide the highest level of surge protection. In your situation, if the power suddenly died it should trigger a reset. (I assume you're using a charge pump). The computer would continue to run and give you time to note where you are in the program in order to do a "run from here" when you continue.
    Regards,
    Walt
  1. startup an shut down code needed
    By jrick in forum Fanuc
    Last Post: 02-09-2007, 11:38 AM
  2. Makino shut down
    By steedspeed in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 11-23-2006, 11:43 AM
  3. servo stall shut off circuit
    By wcarrothers1 in forum DIY CNC Router Table Machines
    Last Post: 10-26-2006, 10:01 PM
  4. Machining in Cold Weather
    By Sprew in forum General Metal Working Machines
    Last Post: 01-29-2006, 11:10 PM
