Old 05-21-2007, 10:53 AM
Jimmyh is on a distinguished road
table size
My 5' table thinks its 42" where do I change that?
Old 08-27-2007, 11:38 AM
tbm2264345 is on a distinguished road
I am in Sri Lankan I interesting making CNC. My works is sandblasting. so i hope by resenabel Prices control Units and Motors Limit Switches. can you help me My Email is info@processlanka.com
Old 08-27-2007, 11:58 AM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
Well, Jimmy - if Mach thinks your table is shorter than it really is, your scaling (steps per revolution) is off.
You can fix this in the motor tuning section.
Mach also has an automated scaling feature. Since this feature is really only needed once per machine, I can not recall off the top of my balding head where it is, but I am sure if you dig, you will find it - I seem to recall it being on the bottom left side of one of the dignostic screens.
It will ask you to command a known distance and then measure exactly how much the machine moved. This is easiest to accomplish with a travel indicator.
EDIT*** - it is located in the settings screen, directly above the E-stop botton, left, lower corner. It states "steps per unit".
Once you go through the scaling steps, your machine should be 5' again.
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 08-27-2007, 12:11 PM
mxtras's Avatar
Silver Member
I might have jumped to the wrong conclusion about your problem.
If scaling is not the issue, you might simply need to change the limits. This is done under the configure pull down menu, then go to homing/limits.
Scott
Old 08-29-2007, 09:21 PM
Thanks I finally got it fiqured out. Ever have a problem with step motors binding up when they get hot?
Jimmy
Old 08-30-2007, 10:33 AM
mxtras's Avatar
Silver Member
Not personally, but it sounds logical.
What motors, drivers are you using and what voltage are you running them at? Running at a higher voltage (if possible) might be a decent solution. Hopefully others will chime in....
Scott
Which size rotary table & chuck style? MichaelHenry Tormach PCNC 7 04-14-2007 10:40 AM
XY table design basics, linear ways to table size ratio? Konstantin Mechanical Calculations/Engineering Design 0 03-13-2007 12:21 PM
X3 base size or minium bench size kenrc Benchtop Machines 2 02-04-2007 06:50 AM
Advice on how to increase table size toddp General Metal Working Machines 1 10-14-2006 09:29 PM
200oz motors vs. Table size? CoffeeRich Hobbycnc (Products) 9 01-15-2006 03:57 PM
