| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
Just like title says, I need help on figuring out steps for my x axis for my router(still in building stage). I didnt have any problems with my z, but x is giving me headaches. I'm using Keling steppers, which then connect to 16 tooth 5mm timing gear which than belt drives 48 tooth gear which than turn 20 tooth spur gear which moves the gantry on gear rack. So i would really appreciate help with calculating steps for this setup so i can start playing with motors turning ![]() The gear rack has 5 teeth per inch(i believe). The drives are currently set for 1/8 microstepping. Thanks in advance for any help! |
| Here is what i'm getting: 200*8=1600 1600/3(3:1 ratio)=533.333 Than this is where i get stuck, the 48 tooth pulley needs to move 1/4 turn to make spur gear move 1". So do i devide 533.3333 by 4? doesnt the number of steps seem low? my Z axis steps are at 16000, and this is coming out to be ~133.33 |
| 200 x 8 = 1600. Steps per rev 1600 x 3 = 4800 . 3 revs of stepper for 1 rev of pinion 4800 / 4 = 1200. This is your 4 inches per rev of pinion divided by 4 to get 1" I only have info on metric gear so not sure about the pitch here. Greg |
Would it be beneficial to me to use 1/16 microstep setting? |
| Microstepping is not really to be depended on to increase resolution. It is more to help the motors turn smoothly. It has diminishing returns and more than 10 generaly does not have much value. I would look at maybe using a smaller pinion. Maybe 20 or 24 tooth |
#11
| OK I was thinking you had a 48 tooth pinion ![]() 1200 microsteps per inch is 0.00083" approx per microstep. Or more realisticaly 0.0067" per full step. IMO perfectly fine for a plasma cutter. If you have not purchased the pulleys yet then consider 15 and 60 which will give you 4 to 1 reduction. Greg |
| Calculating points from a drawing. | ladyz666 | G-Code Programing | 6 | 08-28-2006 09:43 PM |
| Full Steps -vs- Micro Steps | DJB282000 | General Electronics Discussion | 10 | 12-28-2005 11:25 PM |
| calculating inductance | 2muchstuff | General Electronics Discussion | 2 | 11-13-2005 12:27 PM |
| Calculating Filter Capacitance | CapnC | General Electronics Discussion | 5 | 01-04-2005 06:40 PM |
| Calculating "steps per unit" for rotary axis? | Beezer | Mach Software (ArtSoft software) | 2 | 11-28-2004 03:31 PM |
