Old 04-16-2007, 10:23 AM
howling60 is on a distinguished road
reading modbus inputs
Hey all,
i KNOW that I know how to do this, but for some reason, every time i try to sit & write my code, i am getting a massive block...
Basically, i'm writing an m-code for use as a "is an input active" to verify that it's "OK" to move my machine into place... running it through a modbus I/O setup.
I know that i could just map the modbus pin to my Input #_ in Ports & Pins, but would prefer to stay with a direct modbus read/write... as the machine could potentially need more inputs than I am allowed within P&P...
I just can't remember how to directly access my modbus inputs via the vb script that will be within my m-code. If someone could please shed the fog that seems to have lodged in my head over the weekend, i would really appreciate it!
Thank you EVER so much!
-Nate
Old 04-17-2007, 07:41 AM
yeah, so.. figured it out...
Modbus to run GS-2 drive? mecheng10 Mach Mill 13 05-13-2009 08:59 PM
Mach3 with Hitachi VFD using Modbus swinn Mach Software (ArtSoft software) 2 11-28-2008 12:44 PM
EMC2/Modbus......HELP! pauldkeeton LinuxCNC (formerly EMC2) 5 02-18-2007 04:47 PM
modbus device Drew Machines running Mach Software 14 02-11-2007 01:59 PM
Reading only new posts PEU Forum Questions or Problems 1 06-04-2005 10:22 PM
