Old 04-04-2007, 08:12 PM
ata's Avatar
ata ata is offline
ata is on a distinguished road
Question Mach3 make reset after showing the 1st splash picture...???
I downloaded last version of Mach3, installed on old PC with 2GB harddisk, OS Win2K, SP4, Ie6, WinZIp, AdobeReader and no other program.
Somebody there maybe know, why by me the Mach3 make reset after showing the 1st splash picture. Thanks.
System Information:
Processor: x86 Family 5 Model 2 Stepping 11 GenuinIntel~133MHz.
Total Physical Memory: 65.080KB.
I think the physical memory is too low.
Old 04-04-2007, 09:16 PM
grahamshere is on a distinguished road
Hi ata, Well first im no expert but i think you need a faster computer than 133 mhz, Should be at least a 1 ghz, im using 700 mgh and thats slow, also you will need some where near 1 gigabite of ram, i have 800mgb and just getting away with that. Also are you using the trial verson, because if you are you can only do 1000 lines with it so maybe that might be your problem as well. good luck .Graham
Old 04-04-2007, 10:33 PM
ata's Avatar
ata ata is offline
I'm now using for Mach3 PC with Intel Core 2 and 1GB-Ram and I use Mach3 demo for test only to know how is the SX3 machine. Thanks.
None of images showing up rustamd Forum Questions or Problems 3 03-16-2007 11:37 AM
Mach3 External Estop Reset bcromwell Mach Software (ArtSoft software) 2 01-24-2006 10:16 PM
Website Showing My CNC Conversion chris59 Machines running Mach Software 7 01-20-2006 12:08 PM
Can't make stepper do anything with mach3 Apples Machines running Mach Software 10 09-04-2005 02:14 AM
Mach3 Splash Screen Design Competition CNCadmin Mach Software (ArtSoft software) 120 04-01-2005 03:51 PM
