Old 04-04-2007, 11:25 AM
cjchands is on a distinguished road
Mach Lathe - Spindle Control How??
Hi Guys,
I wonder how do you control Power invertor in the spindle on the MACH LATHE? On parallel ports, there are steps and direction to control the motion X and Z, but how do you connect to the invertor DRIVE?
I don't see too much discussion on MACH LATHE so not quite sure if that's how it can be done.
Thank you
Jeff
Old 04-04-2007, 06:13 PM
aminear is on a distinguished road
mach lathe spindle control
Jeff,
You have to take a spindle pwm signal to a Freq to Voltage or pwm to voltage converter card that changes it to a voltage and drive your speed controller with that.
Arnie
Old 04-04-2007, 07:01 PM
ger21's Avatar
Something like this?
http://homanndesigns.com/store/index...products_id=21
Old 04-05-2007, 03:25 AM
Thanks for the response.
So it seem like your recommended DigiSpeed GX input will be connected directly to the PARALLEL PORT output that generated 5V PWM from MACH.
Then Digispeed GX will generate output 0-5Vdc (0-100%) analog that goes into the frequency invertor? However, isn't most Invertor input receive 0-10Vdc?? (Then 0-5Vdc wouldn't that be just half).
Thank you again.
Jeff
Is this how you guys did it?
Old 04-05-2007, 06:10 AM
ger21's Avatar
I believe the Digispeed can be configured for 0-10V as well. Never used one, so don't really know for sure.
Old 04-05-2007, 10:21 AM
The digispeed control will probably work, there is also a dealer www.cnc4pc.com, I bought one of their step/direction to voltage cards, haven't installed it yet but it looks like it should work fine. I haven't installed mine yet because I just changed out my motor control recently, got some swarf in the controller and burnt it up. I was using a simple homemade design where I used a optical isolation to fire a mosfet that charged a cap through a resistor network ( a simple rc filter), feed my pulse into the optical isolater and coupled the output directly to the motor controls.
0-10V output control with Mach 3? fatal-exception Mach Mill 3 01-11-2007 12:39 PM
Des Plaines, IL Needs Help With Mach 3 and Control Box carveceltic Mach Software (ArtSoft software) 0 11-08-2006 12:15 AM
Tangential control with Mach 3 krumly Mach Software (ArtSoft software) 6 10-23-2006 07:44 PM
How would you use Mach to control a bender? panozeng Mach Software (ArtSoft software) 23 10-18-2006 12:40 AM
Mach 3 no spindle - but OK in Mach 2 zcases Mach Software (ArtSoft software) 9 07-31-2006 07:38 AM
