Old 03-29-2007, 09:26 AM
dafowfidy is on a distinguished road
Will Jog but not Move Correctly in G code
Ok so this is kind of weird to me. May machine witch is an open loop machine will Jog .1 when asked but if I so give it a G0 G90 G54 F10. Y1. and I am currently at G54’s Y zero, well it will only move and display on my PC a movement of .8596. Then if I try to send it back to Y0, it falls short again. So it is apparent that I am missing some steps but how is it on a open loop control, I could be reading it on the PC screen as well?
Old 03-29-2007, 09:55 AM
ger21's Avatar
What if just MDI a G0 Y1, does the DRO say 1 then?
Do you have axis scaling on by chance?
Old 03-29-2007, 09:59 AM
No, thats what I dont get, it move and will display .8596? Where is the axis scaling? Wouldent it display 1.000 if I requested 1.000? The machine will just get lost if it never gets to where it is suposed to be.
Old 03-29-2007, 10:28 AM
ger21's Avatar
The scaling DRO is right next to the axis DRO, it usually has 1.000 in it. You must have some settings wrong, I've never heard of Mach not moving what you tell it to.
Old 03-29-2007, 10:40 AM
When I get home I guess I can try it offline, and then with anouther profile I guess.
Old 03-29-2007, 10:27 PM
Problem Found
Ok, it was in my profile someware. Now I have to find out were int he xml or how to fix it through the Mach interface. I tryed a different profile and it moved correctly. Thanks for the help
DFX is not imported correctly... ihkim GRZ Software- MeshCAM 11 01-07-2010 11:57 AM
How to code a step motor axis move? Niggo OpenSource Software 3 08-13-2007 10:40 PM
Are tachometers correctly referred to as encoders? Smertrios Stepper Motors and Drives 8 10-05-2006 06:13 PM
The X-Axles... to move or not to move! Wild4aces Mechanical Calculations/Engineering Design 1 03-18-2005 01:26 PM
