Old 03-18-2007, 06:32 PM
MrToyz is on a distinguished road
Motors on all the time
Hi guy's, here's my issue. Mach 3, dtlls board, 8 wire motors. I have been through all the setups from dtlls and mach 3. My problem, when i turn on my system the motors are energized and in a frozen state. I have checked all the wiring and it looks right. I checked voltage going to the motor and i have my 2 full time 12 volts to the motor but for some reason the board is grounding one side of each coil sets on the motor. Please help
Old 03-18-2007, 07:11 PM
ger21's Avatar
Are you saying you can't get them to spin? They are supposed to be locked up when power is applied.
Old 03-18-2007, 07:17 PM
Thats true they won't spin. But these are 3 amp motors that are drawing 13 amps in idle no load mode. Motors overheat and my wires start to melt if I don't turn things off.
Old 03-18-2007, 07:25 PM
ger21's Avatar
It's not a Mach3 problem then. Definately a wiring issue or a short somewhere.
Old 03-18-2007, 07:52 PM
I might agree with you, but wiring has been checked 3-4 times. It happens on all motors and all axis's. I have wired them in a unipolar method as described by dtllc. I have checked the pinout of the db25 cable and it a straight threw cable. I'm sure it's something I have wrong, I just don't what that something is.
Old 03-19-2007, 07:21 PM
kreutz is on a distinguished road
What is a dtlls board? Could you post a link to the specs?
Thanks.
Old 06-09-2007, 08:00 PM
DTLLC is on a distinguished road
It sounds as if you do not have resistors between the motor and power supply. This could melt wires and possible damage the board or motor. Get the specs on you motors and power supply and contact me. I am sure I can get you running like many others.
David Delagrange, Owner
Delagrange Technology LLC
4024 Fairfield Avenue
Fort Wayne, IN 46807
Phone: (260) 557-9280
Hours: Monday-Friday, 5:00 p.m.- 9:00 p.m.
E-mail: admin@dtllc.com
http://www.dtllc.com
Time to Buy Gorillakilla Stepper Motors and Drives 3 06-24-2008 03:52 PM
milling time (not to be confused with hammer time) barefoot0 G-Code Programing 4 05-02-2007 06:18 PM
Time on Job greasetattoo Carken Products (Deskam, DeskCNC etc) 0 03-10-2007 05:30 PM
X2 Conversion Time (shopping time) Micro Rotors Benchtop Machines 2 03-04-2007 11:11 AM
It may be dos time craig LinuxCNC (formerly EMC2) 5 12-08-2006 02:41 AM
