Old 03-15-2007, 11:24 AM
tehMadmachinist is on a distinguished road
Exclamation Printer port problems
I've got my controller on and can hear that the motors on. But in mach3 when i attempt to jog it doesn't move. I've got the motor outputs set up right, all are going through port 1, steps per inch are set on all the axis' and set on active low as specified. when I go into the diagnostics window there is no printer port activity (no leds light up) when I attempt to jog. Also my enable1 led stays lit even though it is disabled. Any ideas? What settings for the pirinter port do i need to have on in the bios?Any suggestions are appreciated. thanks a lot.
Old 03-15-2007, 04:27 PM
NC Cams is on a distinguished road
What kind of PC? Some laptops have 3.3 volt parallel ports and don't work well or at all with some BOB's that want 5 vdc signals.
This whole laptop vs regular computer topic has been discussed AT GREAT LENGTH on the CNC ZOne.
Old 03-15-2007, 06:44 PM
I have a homebuilt desktop with a Asus motherboard.
Old 03-15-2007, 07:02 PM
Greolt is on a distinguished road
Control panel / system / hardware / device manager, look at the resources on the LPT
Mach defaults to 275 where as it is often 375.
This can be changed in BIOS but if you don't have to....
As to the old chestnut about laptops 3.3v, most desktops are also.
I have five desktops running here and all but one is 3.3v (that one is 10 years old)
Old 03-15-2007, 07:54 PM
is there a way to check and see what voltage it is? And i've tried messing with the port numbers in both the bios and in mach and i can't seem to get it to work. Thanks for the help.
Old 03-15-2007, 07:59 PM
ger21's Avatar
Are the DRO's in Mach changing when you attempt to jog?
Old 03-15-2007, 08:00 PM
ger21's Avatar
Have you watched the Mach3 setup video at www.machsupport.com? It explains how to get the proper port address. Can you post a screenshot of your motor pin setup screen?
Old 03-15-2007, 08:15 PM
Ya i watched the whole mach video as well. And the DRO are changing too.
Old 03-15-2007, 08:21 PM
ger21's Avatar
You didn't install the driver, or it didn't take. On your diagnostics page, under pulse frequency, it says simulate. It should say something close to 25000 . Run drivertest.exe in the mach3 folder. If it doesn't work, uninstall, reboot, and reinstall.
Old 03-15-2007, 08:50 PM
I unistalled rebooted and installed. It never asked to install driver. And I went to the mach 3 folder and tried opening orignialdriver. And that didn't work. Any ideas on how to get driver to install. Running winxp 64-bit
Old 03-15-2007, 08:54 PM
ger21's Avatar
Yeah, don't use Xp 64 bit, it won't work. Must be standard 32bit XP, Vista or Win2K. The install should have a checkbox at the end that says "install driver".
  #12   Ban this user!
Old 03-15-2007, 09:10 PM
thanks a lot for your help. Getting another computer set up for it.
USB to Printer port compatability CbrViking Mach Mill 7 02-27-2007 05:05 PM
printer port tester smarbaga General Electronics Discussion 1 12-10-2005 11:57 AM
Communications output to Printer Port kheri Post Processors for MC 0 03-26-2005 12:40 AM
printer port? replicapro General CAM Discussion 2 11-26-2004 03:37 PM
Have problems with G201 and printer port Christian Gecko Drives 2 09-26-2004 02:44 PM
