Old 03-14-2007, 07:18 PM
bigz1's Avatar
bigz1 is on a distinguished road
Limit/E-stop Problem?
Limits and E-stop work correctly when driver board has no power to it. But as soon as I power up driver board they become active without being depressed. Is this something to do with signal debounce?
Also after reading the manual several times I am confused on how to set up the ports and pins correctly for a solid state relay that turns the router ON/OFF?
Any help would be appreciated.
Old 03-14-2007, 07:36 PM
ger21's Avatar
Your probably getting noise. Try increasing the debounce to 5000 and see if it goes away. If not, keep increasing in 2000 increments and see. But, the higher the debounce, the slower the switches will react.
Old 03-14-2007, 07:59 PM
bigz1's Avatar
Do I set both Debounce Interval & Index debounce to 5000?
I thought it might noise. I have used shielded cable/star arrangement but its connected to a mains earth thats probably dirty.
Thanks Gerry
Old 03-14-2007, 08:17 PM
ger21's Avatar
Not the Index, just the other one.
Limit, Home and E Stop Switches Mr.Chips General Electronics Discussion 15 01-17-2007 09:02 AM
E-Stop Problem?? ZR Machine Haas Mills 14 01-30-2006 10:54 PM
Another E-stop, Home and limit post binary_d Mach Mill 2 10-05-2005 06:19 PM
Home/limit/e-stop problems The Wizard TurboCNC 4 05-16-2005 03:46 PM
E-Stop Home/Limit Questions Sanghera General Electronics Discussion 0 10-09-2004 01:40 PM
