Old 03-10-2007, 08:13 AM
studysession is on a distinguished road
2 steppers on one axis
Hi -
I am building a 6 axis routing table. And I use Mach3.
I want to use 2 stepper motors on my X-Axis. Question is how do I set this up in Mach3 to also still alow me to use all 6 axis? Or does it limit me to 5 since 2 motors have to be controlled for my X-axis?
I want an X, Y & Z along with a A, B & C axis.
ID:	33303   Click image for larger version
Please check out my CNC blog
http://cncinside.com
Old 03-10-2007, 08:20 AM
ajl6549 is on a distinguished road
Originally Posted by studysession View Post
Hi -
Just curious, but why not 5 axis?
A.J.L.
Old 03-10-2007, 08:24 AM
Not many people build 5 much less 6. So I want to do it for the learning experience. Hopefully it will actually be useful as well.
I see where 5 axis is very useful but not really sure if I need 6 or not. I just want to do it for the know how.
Old 03-10-2007, 09:19 AM
In your rendering of the knee type mill which would be the c axis? On the gantry type machine what would A axis be.
P.S. IMHO the 5 axis gantry type machine would be awsome!
A.J.L.
Old 03-10-2007, 09:23 AM
ger21's Avatar
You only get 6 motors in Mach3, + a spindle.
One thing you could do is split one set of step and direction pins to two drives, so both drives would run off the X axis pins.
Old 03-10-2007, 04:05 PM
Is that ok to do? Run two motors off same set of pins like that?
Old 03-12-2007, 11:28 AM
steve323 is on a distinguished road
Each parallel port output drivers should easily be capable of driving two or more loads. It probably has a simple CMOS driver in the computer. The receiver is probably a CMOS input buffer with no current, except for a weak pullup resistor. Two loads should be no problem.
Old 03-12-2007, 12:34 PM
Moderator
JerryFlyGuy is on a distinguished road
Your limited to 6 motors as Ger21 said, you could connect two motor's to the same step/dir pin's however it is discouraged for several reason's. Mariss can explain it better than me [if you do a search on the GeckoDrive list on Yahoo you'll find it as this question was asked about a week ago].
You'll not have accurate homing w/ two motor's on one set of pins and lost step's won't be detected w/ a home/verify.
The real question at the end of the day is what the heck are you going to do with 6 axis, and what CAM are you going to use? BTW, the pictures you've posted only are 5 axis machines.. Where are you going to put the 6th axis?
Curious..
Jerry
JerryFlyGuy
The more I know... the more I realize I don't
Old 03-12-2007, 01:04 PM
Curious..
Jerry
My ques. exactly.
A.J.L.
Old 03-16-2007, 07:57 PM
Yes - I realise they are pic's of 5 axis machines. Take the picture of the gantry router and add the A-axis from the other and then you have 6 axis.
Do I really have to have that many. Nope - but I figure why not build it anyway.
Old 03-16-2007, 08:04 PM
ger21's Avatar
Bacause you won't be able to program it??
  #12   Ban this user!
Old 03-16-2007, 08:45 PM
Not to mention the more variables you enter into the equation the better the chance of a malf.
A.J.L.
Different steppers on each axis? pulsar200 DIY-CNC Router Table Machines 20 09-03-2006 10:59 AM
multiple steppers per axis Yint Mechanical Calculations/Engineering Design 1 05-17-2006 02:12 PM
X axis - 2 steppers 1 gecko ? andy_ck87028 Gecko Drives 3 11-17-2005 02:50 PM
2 steppers on same axis CanopyFx DIY-CNC Router Table Machines 5 05-02-2005 10:48 AM
2 servos/steppers on 1 axis? m_c General Electronics Discussion 15 07-17-2004 09:44 PM
