| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
I am at the point in my mill conversion that I need step and direction pulses tomake finish it off. And so, I load Mach 3 and go into the ports & pins setup. Step pin is 2, direction 3. Before I attach motors, I just thought I would put a voltmeter between step and ground and direction and ground, just to make sure all is functioning. I tried it with a bare bone's breakout board, 0 volts everytime I tested. I was holding down the mouse button to jog. I tried it with a CNC4PC board that replaces the 3.3v pulses with 5v pulses, same result. I tried it with KCAM after that, thinking maybe it's some of my hardware. Well I got 3.31volts with the bare bones breakout board. And the CNC4PC functioned well, it rectified all to the full 5v. With both programs I am trying to jog in the X axis (not hooked up yet). Can anybody think of some possible causes of this? |
| Make sure that the port you are trying to control is enabled and set to the correct address in Mach3 under 'Config -> Ports & Pins'. Most parallel ports use either 0x378 or 0x278 as the assigned address. If you are using an I/O card the address may be something else entirely. My I/O card, for example, was assigned and is using address 0x1020. Verify the address of your parallel port using Windows Device Manager -> Ports (COM & LPT) -> 'Your parallel ports Properties' -> Resources Tab. See screen captures below...
__________________ HayTay Don't be the one that stands in the way of your success! |
| Also make sure each pin is NOT set to port 0, which is the default i think. And if you measure 0V on the direction pin while jogging, jog in the other direction. One direction should be 0V, the other direction 5V.
| Your step and direction port settings are wrong (the last 2 columns). They should all be set to port 1, You have the port number matching the pin number. You only have one port, port #1
| As long as port 1 is the one you're using.
| SPC Ports What are your Use? | SMW Precision | Calibration & Measurement | 1 | 07-31-2006 03:46 PM |
| ports and pins | planescott | Stepper Motors and Drives | 5 | 03-24-2006 11:57 PM |
| Parallel ports | itsme | Computers and Networking | 8 | 09-30-2005 08:20 PM |
| 3.3 V vs. 5 V TTL on parallel ports | HansM | Machine Problems, Solutions , Wireless DNC, serial port | 4 | 07-28-2005 02:28 PM |
| Pins setup for gecko G 201 | engraver | Mach Software (ArtSoft software) | 7 | 07-23-2003 01:17 AM |
