Old 02-18-2007, 05:22 AM
timeout555 is on a distinguished road
Question MACH3 and noise from stepper motor
Finally I got my motor running on MACH3 with the kind help of CNCzone members, had 3 problems though:
1- The motor noise bocomes higher when i start up MACH3,
2- With large motor the motor steps one step back and forth, with smaller motor the motor steps CCW
3- The movement is kind of sluggesh and slow, when using large motor (100oz-inch)
I really appreciate your help
Old 02-25-2007, 07:46 PM
Drew's Avatar
Drew is on a distinguished road
When I first got Mach3 running my motors sounded and ran awful. I changer the setting to step low active and it ran fine.
Old 02-28-2007, 03:33 AM
Question Cannt get to it
Thank you very much for the information, but it seems I cannot get to the right menue to (Step low active)
thank you
Old 02-28-2007, 09:39 PM
Drew's Avatar
Its in the ports and pins menu . Its set to a green check or a red x.
Motor Humming Noise? Dman Hobbycnc (Products) 12 11-09-2008 06:03 PM
stepper setup, Electrical noise ? veteq Stepper Motors and Drives 3 02-07-2007 10:31 PM
RF noise causing stepper chatter PsyKotyk General Electronics Discussion 3 08-08-2006 08:42 PM
Motor noise mjarus Mini Lathe 1 04-03-2006 09:57 PM
noise from motor georgebarr DIY-CNC Router Table Machines 2 05-13-2003 07:43 PM
