Old 01-15-2007, 02:42 AM
judi is on a distinguished road
Red face pinout (for MACH software)???
Iam going to design my controller circuit
to control three stepping motors ,
and i will use MACH2 software.
But I do not know pinout of parallel port that match the signal/dir
Any one have information for this.
Old 01-15-2007, 08:11 AM
Barker806 is on a distinguished road
Open the ports and pins and on the input and output pages it will tell you what pins you can use.... 1-9 can be used for motor outputs
Old 01-15-2007, 08:14 AM
Thanks Barker806
I will try this.
Old 01-23-2007, 02:51 PM
eibbor is on a distinguished road
Hi Judi,
One other thing, check the cable you are using for this. Here is a link I found on the other foum that might help. There are sevsral different pinouts for db25 cables. I like the straight through and a lot of pre-made boards will only work with these.
http://www.machsupport.com/forum/index.php?topic=1898.0
Hope this helps.
eibbor
Old 01-23-2007, 02:59 PM
Oops, new here.
