| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
I keep getting the error "Radius to end of arc differs from radius to start on line number #15" It also gets that error on lines 20 and 25. I am trying to cut a disk 7 inch in dia with three passes of 0.26 inch at a feed rate of 5 inch per min. with the center of disk at x0, y0. and a bit of .25 dia. N0000 (Filename: Drawing1.tap) N0010 (Post processor: Mach2.post) N0020 (Date: 11/12/2006) N0030 G20 (Units: Inches) N0040 G40 G90 N0050 F1 N0060 (Part: Drawing1) N0070 M6 T3 (Mill/Router, 0.25 in diameter) N0080 G43 H3 F5 N0090 M04 S0 N0100 (Process: Outside offset 0, Mill/Router, 0.25 in diameter, 0.78 in Deep) N0110 G00 Z0.3750 N0120 X0.0000 Y-3.6250 N0130 Z0.0197 N0140 G01 Z-0.2600 N0150 G02 X-3.6250 Y0.0000 I-0.0000 J3.6250 N0160 X0.0000 Y3.6250 I3.6250 J-0.0000 N0170 X3.6250 Y0.0000 I0.0000 J-3.6250 N0180 X0.0000 Y-3.6250 I-3.6250 J-0.0000 N0190 G01 Z-0.5200 N0200 G02 X-3.6250 Y0.0000 I-0.0000 J3.6250 N0210 X0.0000 Y3.6250 I3.6250 J-0.0000 N0220 X3.6250 Y0.0000 I0.0000 J-3.6250 N0230 X0.0000 Y-3.6250 I-3.6250 J-0.0000 N0240 G01 Z-0.7800 N0250 G02 X-3.6250 Y0.0000 I-0.0000 J3.6250 N0260 X0.0000 Y3.6250 I3.6250 J-0.0000 N0270 X3.6250 Y0.0000 I0.0000 J-3.6250 N0280 X0.0000 Y-3.6250 I-3.6250 J-0.0000 N0290 G00 Z0.3750 N0300 M05 N0310 G49 N0320 M05 M30 |
| Try changing your IJ mode. It should be set to Incremental, and it's probably on absolute.
| here is the corrected code, I also ran yours in ncplot % O0000 (PROGRAM NAME - CNCZONE) (DATE=DD-MM-YY - 12-11-06 TIME=HH:MM - 21:48) N100G20 N102G0G17G40G49G80G90 ( 1/4 FLAT ENDMILL TOOL - 1 DIA. OFF. - 1 LEN. - 1 DIA. - .25) N104T1M6 N106G0G90G54X3.625Y0.S0M5 N108G43H1Z.25 N110Z.1 N112G1Z-.26F5. N114G2X-3.625R3.625 N116X3.625R3.625 N118G1Z-.52 N120G2X-3.625R3.625 N122X3.625R3.625 N124G1Z-.78 N126G2X-3.625R3.625 N128X3.625R3.625 N130G1Z-.68F6.42 N132G0Z.25 N134M5 N136G91G28Z0. N138G28X0.Y0. N140M30 % |
| Gary, there was nothing wrong with his code. His IJ mode in Mach was set wrong. It's supposed to be a circle, not what your picture shows. His code runs fine here.
