Old 10-01-2006, 12:21 PM
fred klusmann is on a distinguished road
mach 2
What is the best laptop for Mach 2
I must bij one
fred kl
Old 10-01-2006, 01:20 PM
NC Cams is on a distinguished road
Laptops can be problematic.
Battery management software can cause hang-ups and other problems. Low power/low voltage LPT ports may not drive the break out boards adequately - the low voltage signals are also more susceptible to noise than a regular 5v system.
A number of Mach users will contend that laptops are not the best choice for use with Mach. Yet, others will say that a laptop is just fine.
The subject was discussed fairly deep in one of these threads but I can't recall which one:
FINALLY started BIG_CNC_LATHE conversion
NC Controller difference
Interest in Lathe retrofit
Although the threads involve lathes, the Mach laptop issue would pertain no matter what the machine.
You might want to check out the Mach support site - surely this question has been posed and answered any number
Old 10-02-2006, 10:29 AM
drawbar's Avatar
drawbar is on a distinguished road
I have had good luck for a couple years now running Mach 2 on my Dell Latitude.
Brian
