Im trying to setup some Mach2 software to work with my Taig Micro mill.
The instructions the Taig cam with say to set the steps per unit to 8000 but this is not correct as If you do this the table moves all of its travel and the Axis DigitalReadOuts only say it has moved maybe one or two mm's.
Has anybody got there Taig MicroMill working with Mach 2 software? If so what setup do you use that works?
